Wind versus Coal
An interesting little side piece in E+T.  It will require 233  5 MW wind turbines to replace one 500 MW coal fired power station. This will occupy 55 square mile. This is also assuming quite a high capacity factor of nearly 43% but I will keep to the quoted numbers.
I am not sure if it is viable /sensible to build new coal fired power stations. The Chinese and the Indians certainly think that it is. So to look at the nuclear option:
To replace a 3 MW nuclear power plant with 2 EPR units, Hinkley point C or Sizewell C, will require 330 square miles to be filled with wind turbines (maybe more depending on the wake effect).
www.wind-energy-the-facts.org/wake-effect.html
This is more than twice the area of the Isle of Wight, not impossible but politically very difficult.
The more important question is the resources required. It is difficult to find numbers for the concrete and steel requirements for wind turbines. I do understand that this is affected by the ground conditions and foundation requirements however some number exist in this 2011 document.
pubs.usgs.gov/.../sir2011-5036.pdf
Table 5, page 12,  gives 100 tonnes of steel per MW and 400 tonnes of concrete per MW.  So to replace Hinkley Point C will, according to Kurt Cobb, require 6990 MW of wind turbines.
Steel 6990 * 100 tonnes  = 699 000 tonnes
Concrete 6990 * 400 tonnes = 2 796 000 tonnes.
The quoted figures for Hinkley Point C are:
Steel 280 000 tonnes
Concrete 3 000 000 tonnes.
https://www.newcivilengineer.com/innovative-thinking/projects-innovation-drives-hinkley-point-c-16-01-2019/
https://chamberuk.com/chrisfayers/
So similar amounts of concrete and a lot less steel for Hinkley Point C. The NPP has an expected life span of 80 years, wind seems to be typically 20-25 years.
Hinkley Point C could also use a lot less materials, cost less and be on time if it was built somewhere other than the UK:
www.spectator.co.uk/.../
Is wind power a sensible use of our finite resources?
  • Hello Mike:
    You can have the most rigid legal standards on products and services and have corrupt individuals at high levels certify defective products.
    As an example one of the companies I worked for, purchased/merged with a well known company (that I can not mention). I discovered that this purchased/merged  company had not been testing their product to the defined government standards. I quietly had to correct the problems as many high level personnel had transferred to my company.
  • Wind, Solar, Wave/Tidal and Hydro are all well and good as alternatives to Coal, Gas Deisel and Nuclear but the renawables only work when there power source is in play.  Eg Turbines with no wind do not run the National grid.  The other thing to consider is the lack of redundancy.  As a casing point the Porth Wen Solar Farm in the north Anglesey which is owned by EDF Renewables had it's output reduced after storm Darragh.  Other factors to consider are or should be why we buy in power from abroad?
    Renewalables on the National Grid need to be backed up by very large battery storage sites also connected to the grid this would allow us to store a certain amount of the energy on lets say a windy day to be used on a calm or windless night.  The battery storage would also allow for the turbines to be constantly working rather than what sometimes happens is they are turned off from generation as too much power at that time is being generated.  The same ethos applies to large scale solar PV farms
    People also need to look beyond the GreenWash for the lack of another word or cliche.  Yes the UK has reduced the amount of coal fired power stations but is real terms all that has happened is coal fired power has been replaced for gas powered
    What needs to happen in the UK is that Engineers need to drive the UK power policy not politicians.  The UK government needs to set up a department for energy that has more engineers working in there than administrators or politicians.
  • Other factors to consider are or should be why we buy in power from abroad?
    International connections do seem to be proving useful in balancing wind power - while a good sized high pressure system can occasionally  be large enough to becalm much of the UK at the same time, it's very unusual for them to be large enough to becalm the UK, Ireland, Western Europe and Northern Europe at the same time - so while it's sat over us we can import, and then when it's moved on and becalming someone else we can reciprocate. We already have cables to France, Ireland, the Netherlands, Norway, Belgium and Denmark.
  • The interlink to France was put in with the channel tunnel and over the last few decades the amount of Mega Watts from France to the UK is a lot higher than what some people might expect.  Conversely how much power have we exported to France, very little.  Then there are the transmission lines from Scotland to England which lack the capacity so there is a limit on how much can be sent from Scotland to England.  The UK are far to reliant on foreign energy, we need to produce our own and store our own and consumer our own
  • Yes the UK has reduced the amount of coal fired power stations but is real terms all that has happened is coal fired power has been replaced for gas powered
    We haven't merely reduced the number of coal fired power stations.  The last one was shut down earlier this year.
  • Hello Sergio:
    I watched a youtube video yesterday on the damage caused at  Port Wen Solar Farm with smashed solar panels due to storm Darragh.
    It also highlighted storm caused damage on wind turbines.
    It mentioned that if this power generation operation had been nuclear it would have not been damaged and would have worked for 70 years without such problems
    Peter Brooks
    Palm Bay FL USA
  • If Port Wen was nuclear, they would still be building it.  They only started building in 2022.
  • So it was only built in 2022 and within 2 years it was seriously damaged by a major storm.
    The guy who made the video about the damage claimed that storm events like Darragh can be expected at that location about every 5 years and that all claims that they will last for 25 years are bogus.
    The other point he made was that the amount of sunlight falling on the solar panels each year at that location is fairly low.
    So your point is that the current UK construction industry is incapable of building any major project!
    Based on the HS2 project, I think I agree with you!
    Peter Brooks
    Palm Bay Florida
  • Hello Simon
     Coal discontinued YES but Wood chips are still being used.
    Peter Brooks
    Palm Bay  FL.
  • Hello Andy:
    You have to ask yourself if old weather patterns (highs and lows) in Europe and the UK will continue into the near future, as climate change accelerates!
    Ask the people in Spain who lived through the floods in 2024.
    Peter Brooks
    Palm Bay FL USA
