Iberien Peninsular Blackout
Any thoughts/information on what happened? Was it a lack of spinning reserve?
Was it " The Portuguese operator, REN, said the outage was caused by a “rare atmospheric phenomenon”, with extreme temperature variations in Spain causing “anomalous oscillations” in very high-voltage lines."
as is written in the Guardian?
Electricity restored to 90% of Spain and most of Portugal after massive power outage | Spain | The Guardian
The Italien blackout from a few years ago had a definate cause in the tripping of interconnetors from Switzerland during a storm.
  • This is the E&T magazine's summary of the report.    E&T magazine Iberian blackout
    David
  • I note that mentions reactive power as well - but the authors have put it in quotes, as if they are not sure if 'imaginary' currents are quite as 'real' as real ones ;-)
    Hehe.
    I've always thought that calling things 'imaginary' because they are phase shifted to be orthogonal relative to 'reality'  a very misleading choice of naming convention. Thanks maths department.  However, I'm not sure that the engineering folk calling it 'reactive' power is much better. Perhaps the metalanguage we use needs a bit of a rethink. 'Early and late' currents or 'tidal circulation' might be clearer. We need to imply the sort of rolling pay day loan of electrons with a lot of effort but nothing useful being done.
    Edited for typos. I probably should not post things quite so late and / or after a beer...
  • Fascinating stuff, thanks for this.
    I suppose the next question is, could it happen in the UK?
    De we have different/ better standards for generators to be connected to the Grid?
    Paul Adkins
  • Probably not identical, but something rather like it certainly could happen here - there are a number of things about our grid management that are assuming that all the sources behave much like conventional generators, i.e. the frequency tries to slow down when overloaded leading to phase shifts between current and voltage that can be detected and acted upon in slow time, for a very short duration overloads can be massive > 100% without anything bad happening, and critically as here, a spinning thing can switch from motor to generator and back, to absorb energy either for several cycles or during one part of the cycle, while trying to speed up a bit and push the power station  round, and then give the excess energy back slightly later, much like a mechanical flywheel.
    An electronic set-up can be designed to emulate this to some extent, perhaps putting more current out near the voltage zero-crossing than at very the tops of the waves, or drawing current from one phase to pump up  the others at different points in the cycles, but it is not the easiest thing to get right, and does not occur as a natural feature of the mechanics, because there aren't any.  So to fake that,  it needs to be measured and acted on more or less on a cycle-by-cycle basis.
    And of course, overload - the jokes about transistors being the fastest fuses on 3 legs are based on unfortunate facts. True cycle duration energy storage, without moving parts ,rather than emulated, requires large inductors and/or capacitors, and at grid scale this becomes a serious and bulky engineering exercise.
    The real situation is we have something over 100 years of running a conventional grid, and it is well understood and ridiculously reliable. The new stuff is by comparison less well known, and the rarer occurrence corners of the problem space are yet to be fully explored.
    To an extent, the rules on when things should disconnect, and how they should behave when over-under loaded need to be reviewed, and at the same time probably some odd looking extra buildings with measurement and telemetry and something heavy inside that emulates the mechanical inertia will need to be designed and connected.
  • Yes, the problem can be that wind turbines and solar all are designed to produce DC and then synchronise with the grid. But if hydro and atomic generation supply line suddenly disconnects then instability occurs and cascade tripping result in black outs everywhere.
    Redesign future wind turbines to run AC at 3000/N revs would much improve stability in UK.
    In sunnier climates note that solar panels are only 25% efficient and costly in dwindling material. But using mirrors and central solar boiler 75% efficient can be obtained to heat water and run steam turbines that are mechanically connected to rotating inertia generators good for frequency control.
    Mechanical generation is protected by Woodward systems which instantly check the balance of forces on the rotor bearings;      quite how you can digitally simulate that by just looking at volts, amps, and Cosine angle I am not sure nor what action could be taken to restabilise the frequency.
  • Redesign future wind turbines to run AC at 3000/N revs would much improve stability in UK.
    Entirely sensible for hydropower where we control the flow. Harder for wind, as I am not sure what you intend to do to the climate to ensure a constant wind speed over time !!
    Truly synchronous wind turbines would have a very narrow range of wind-speeds with high efficiency.
    Long term I think the solutions will come and will involve power electronics and more telemetry.
  • for reassurance, look here www.neso.energy/.../reactive-power-market
  • Thanks for that link. Looking there & finding
    Publicly Available 1 Voltage Technical Requirements and Specification
    and
    Publicly Available Stability Technical Requirements and Specification
    Is actually only partly re-assuring - the  circulating current problems of waveform quality (things that are really not simple sine-waves) and phase shift are not separated, indeed reactive power is purely considered in terms of the fundamental frequency, with no mention of harmonic content
    e.g.
    " Reactive Power The product of voltage and current and the sine of the phase angle between them measured in units of voltamperes reactive"
    For now, its good that it is being discussed but the technical language is still that of a traditional rotating grid where changes in frequency are synonymous with a load response...
    An inverter based system need not present any RoCoF with load, or indeed you could design it to give a negative one, if you like.
  • Electrical energy per cycle, is a volume of rotating Magnoflux inertia with voltage at right angles to current and both at quadrature to the flux or a Cosine quantum reduction will occur as VAR's.
    Not sure how above Equation 1  helps resolve the problem of cubic volume synchronisation ?
  • Hello Clive:
    What has "quantum" effects have to do with this situation?
    Peter Brooks
    Palm Bay FL
