When a 4 CT protection relay is used for a 3 conductor feeder, will the earth fault relay becomes more sensitive if compared to a 3 CT set up? When the feeder loading is high, will the induced magnetic field of the line conductor cause the unused neutral conductor to have nuisance Neutral CT secondary current to flow to the relay and cause the relay to detect as earth fault current in the system?
