John Peckham:
The changes relating to this requirement were the move of the 40ms at 150mA from Chapter 41 to Part 6.
The big change I strongly object to is testing RCDs only at x5 or higher. The higher bit is just stupid! I have heard one manufacturer recommending a test at 250mA. What is the purpose of this test is it to get the RCD to trip? Or should it be a test the RCD at a potentially lethal current and verify it will disconnect the supply in a safe time.
Graham Kenyon posted a very good table on the old forum for testing of RCDS that I think should appear in the future AMD1 to the 18TH.
I note that the sad posts by Zoom of a double fatality concerning a shower and GB post of a fatality in rented premises could have been prevented by RCD protection.
Sparkingchip:
What were we taught twenty years ago about testing RCDs, some of us are old enough to have installed consumer units where the requirements for RCDs of anything other than TT installations was basically none existent. New houses built on estates in the 1980’s that had TN installations had a socket with a built in RCD in the garage for outdoor use and that was it.
So what were we taught about testing RCDs twenty years ago when split load consumer units were becoming the norm .
Andy
No RCDs in sight and all rewireable fuses - did charred bodies litter the pavements back then? No, it was normal to us.
When RCDs first came in fashion it was for a dedicated new circuit (say shower) or more often a front ender either on tails to consuimer unit or as the mainswitch of a consumer unit itself.
In fact wylex changed their rocker switch colours when down for ON started to lose out in favour of up for ON.
Happy days?
Could it be that for additional protection, the max trip time at 5 IΔn is appropriate, but for ADS in a TT system, it is the max trip time at IΔn which is important?
