Vintage accessory
2044feaad45ad07de85c1293a8c290ec-huge-df1dcd8e97e1040e5c61e66049ce02b3-large-20181129_100549.jpg
Try ID'ing this accesory removed  from
a bungalow unchanged since built. Possibly 1940ish.  Altough i have seen similar none have been like this.  More pics to follow.
    This picture shoes the fuse removed which would normally  be screwed externally  into the plug.
    I'm unaware of any 2/5/15 A plugs vintage plugs incorporating this fused pin. Modern 2 and 5 A yes but vintage no. I've only ever seen this fused pin used on some Reyrolle industrial scraping earth plugs in line with BS 196 of 1930 &/or 1961.
    I've grabbed a 1931 catalogue which shows this type of accessory but in a 1951 catalogue, the range is reduced due to the acceptance of 13 A  plugs & sockets
    I know, I need to get out more.........
    BOD
  • low current fused pin plugs have a long history, being prewar as  well as the alternative 13A plugs  that never caught on despite the distressing tendency to snap off in the socket and leave a live end protruding.
    Allowed 5A lights to plug into 15A sockets and similar. Rather pointless as un-fused plugs were always available that fit the same sockets.
  • Lozmic:
    Close enough Mr Z. And yes the top just unscrews.
    Its a surface mount single switched 13A socket. Designesd for a 3pin plug where the fuse actualy plugs into the socket. Very heavy and the switch has a reassuring action. Made by GEC. 4e5b424dd306e6676475798899531f23-huge-20181129_100837.jpg
    Probably designed for days of yore, requiring a positive switching action for D.C. switching and not microgap as nowadays
    Jaymack
