Why are we taking dangerous Voltages out to electric vehicles to charge them? Can't a safer lower Voltage be used?
The same reason we always find ourselves using high voltages - we like the same power with low loss and in the case of car charging
at a less fantastic current. A 32A charger at 230V could be a 300A charger at 24V, but the cable and connector requirements are a bit unwieldy, and the slightest rise in resistance from corrosion or whatever becomes a fire hazard, and even a 1V drop (1/300 of an ohm) is a significant fraction of the total 24v
If we have low voltage and low current then we have long charge times.
mapj1:
Why are we taking dangerous Voltages out to electric vehicles to charge them? Can't a safer lower Voltage be used? Perhaps having the vehicles' batteries divided into separate smaller banks for charging.
AJJewsbury:
Probably a lot simpler just to make the entire thing (EVSE and EV) double insulated.
AJJewsbury:
Simon Barker:
Given the long history of connecting the battery negative to the chassis, and then using the chassis as the negative "wire", I can't imagine it's that easy to create a double insulated EV. And you couldn't assume any existing vehicles were double insulated when designing charging stations.
