BEST ELECTRICAL JOKE OF THE WEEK?
Good morning fellow forum members.
I was doing an I&T on Friday with one of my merry men, Bob. We were working in a plant room that contained the incoming supply and distribution. The conversation went like this.
JP, " Can you isolate the other end of this circuit to the mortuary so I can do an IR test?
Bob, " That will be a waste of time.
JP "Why?"
Bob. " Because it will be a dead short".
  • I bet you were mortified by that remark
  • OK, so you are fitting out a new mortuary, where do you put the luminaire?
  • Err a bit of a shot in the dark but, the dead centre?
    No doubt someone will be along with, "people are dying to get in there"?
    Or perhaps "only 2 of you, clearly a skeleton staff".
    Or " How many terminals".
  • Il y a eu plusieurs mort. Mort de peur.
  • Beware! Death can be fatal - Once!
  • Nope you are wrong there I think. On my third attempt at reviving someone I was successful, and he was my oldest patient.  Chris P may be able to clarify the if this is technically correct and reversing death is indeed possible?
    For your information and for the avoidance of doubt I am the world's worst first aider and a glowing example of practice does not  make perfect!
  • John Peckham:
    There is a reasonably widely held misconception that cardio-pulmonary resuscitation brings people back from the dead, but in fact it stops people dying at the very last moment. A 1:3 success rate, particularly out of hospital, is most impressive. Well done! ?
    I might add that it is useful to have a defibrillator - electricity can kill, but it can also revive. The nearest one to me right now is at the local church about 300 yards away. Unfortunately, I cannot quite see Mrs P running over there and back within the vital 3 minute window of opportunity should I collapse.
    Back on topic, the churchyard has no graves, so no, a defibrillator has not been installed in a graveyard. ?
  • Chris
    I did work for an organisation part time where we had to say " apparently lifeless body of Mr Smith" as only a doctor could pronounce death even if very obvious.
  • Chris
    Have you thought of equipping Mrs P with a bicycle for emergency use?
