Chris Pearson:
Dbat:
Thats fine until a few years down the line when such records have been lost, and some poor electrician is struggling to fault find on a lighting circuit with only one cable at each light and switch. Then he's got to play russian roulette taking up carpets and boards to guess where this mystery central box you've installed is hidden under the floors. Any such box needs to be easy accessible and to easy to find. Even in a loft you'll be up and down the ladder alot disconnecting circuits to break down the fault, so whats the real benefit?If the records are kept in their proper place, which is within or adjacent to the DB (514.9.1), how do they get lost?
And please somebody, tell me why a competently constructed installation should become faulty? ?
That may work unless Madam has set her heart on some wooden sockets, or other design in which appearance is more important than durability or function.
It may work well for a row of sockets behind a desk or in a kitchen, but you are surely not going to have a horizontal chase all the way around a sitting room? So either you use a JB here and there, or else you bring the wires up (or down) to a socket and back, in which case it is beginning to look like a ring.
Just me then (?), though to be fair not often, and I agree it feels 'wrong', but I have a couple of cases I recall, once actually in a conservatory, where there was no roof void to go up into anyway, and another in a kitchen, with flat above and below having a solid floor, so the wiring was horizontal between boxes below counter for appliance sockets and pops up for sockets and switches.
But it is spurious, and as far as possible, all joints should be in back boxes of sockets or switches, or if in the ceiling, perhaps in these things round dry line boxes, with lid which at a push can take a stuffing gland, in places where a ceiling rose would go if there had been more room for it.
In a well designed layout, there should be an absolute minimum of joint boxes of any kind. I agree they are occasionally unavoidable, but undesirable.
Chris Pearson:
Dbat:
mapj1:
But it is spurious, and as far as possible, all joints should be in back boxes of sockets or switches ...
Sparkingchip:
Installing lighting circuits using junction boxes is not good installation practice.
Are you implying that Surewire junction boxes are anathema, or even completely heretical, to professional electricians?
One criticism I have of them is that they do not manufacture a junction box that fits inside an electrical back box. Such a junction box mounted in a wall will eliminate issues with junction boxes concealed (or made difficult to access) beneath floorboards.
Correct me if I am wrong, but the ceiling rose junction box was originally designed to reduce costs of a lighting installation as opposed to improving fault finding or eliminating screw terminals in junction boxes installed beneath floorboards.
Arran Cameron:
Sparkingchip:
Installing lighting circuits using junction boxes is not good installation practice.Are you implying that Surewire junction boxes are anathema, or even completely heretical, to professional electricians?
