Dbat:
What does it matter what it was made for? Have you ever tried to do some basic circuit fault finding? Easy access and splitting up of cables is the name of the game, and your going to struggle if the previous person went down the central hidden junction box route aren't you?
Dbat:
Sparkingchip:
Faulting by halves is the standard approach to fault finding an electrical circuit.
Guess where the middle is, separate the two halves of the circuit, identify the fault half and repeat the process on that half, then keep repeating until you get to the fault.
It is not unknown to half to chop a cable into sections with cutters to break it down for testing, then to have to join it back together again removing the fault as you do so.
If you can simply disconnect the cable ends at switches or light fittings this can be done quite quickly and efficiently.
If you have to start lifting carpets, laminate flooring, tiles, the sub-floor and floor deck itself to find the junction boxes then separate the cables, you really are not going to be popular with customers if you installed the junction boxes or for that matter even if you are the person trying to sort the problems out.
Andy Betteridge
What are the commonest faults found on lighting circuits?
Is a loop-in topology with ceiling rose junction boxes more or less reliable than a radial topology with ceiling rose junction boxes? Which of the two topologies is easier to fault find?
Are installations where just one cable emerges from the ceiling for each ceiling rose or light fitting generally more reliable than installations where 3 cables emerge from a hole in the ceiling for each ceiling rose or light fitting?
Arran Cameron:
Specifically for lighting they tend to be at luminaire positions (often heat related or poor terminations due to space constraints), followed by switch positions (removal/twisting about for decoration etc) and then more common to the rest of the installation to the wiring generally where buried in walls, under floors etc (over ambitious SDS or nail gun activity)
If you know where the JB is, and have easy access - for me the latter. I often used a double socket box strategically positioned as a joint box for a group of luminaires and switches (what was often known as RB4 method after the catalogue number of the JB)
In my opinion yes (but that very much depends on the luminaire that's being installed) - a ceiling rose with loop in is pretty bomb proof - cramming all the connections into an IKEA chandelier less so)
