Leakage Current at 250 VAC 50 Hz <10% of Rated Current
In a TT system without something to tame the earth leakage ? - the leakage on a 60A filter is not to be sneezed at.
Even these N900 series manage to leak the best part of an amp to earth in normal use.
The usual wheeze is to trim the capacitances from the 3 phases, so that the resultant leakage is near zero, but this active approach should allow results that are as almost as good on a single phase system, or a system where only 2 phases are used.
The key thing however is to be very clear about how the part that is not under RCD protection is to be kept safe - if it is all in the one box, and the effect is that a piece of closed class 1 equipment has a low earth leakage, no one will question how this is achieved, but this technique allows the wiring that is after the active current cancellation to be part of the fixed wiring, and that is I think a novel step.
I'd want to see the bulk of the installation being low leakage and RCD protected, so the magic current injection box as close as possible to the filters, and those in turn close to the inverter - and all of that, I'd like to be enclosed, such that additional protection by RCD is not really needed, as it may not have it.
I agree if you do not allow cancellation at 50Hz, then the load side circuitry is still RCD projected to a degree, but then the dominant leakage current is not being ameliorated either, which sort of defeats the best point of the technique somewhat.
I was also thinking of a reg that prohibited introducing voltages(?) to an RCD other than those required for periodic testing by an approved testing device, but cant find it
davezawadi:
. . . I can see very little reason to fit one to VSDs, because they do not usually drive socket outlets, although there may be a case if the supply is TT, but 30mA protection is very unlikely to be required. . .
