Supporting overhead CAT6 SWA
Would CAT6 SWA cable require any additional support if used for say a 5 metre overhead span?
I have seen what looks like either split-con or concentric cable used overhead without no obvious support wire.
If suitable, what are the best options to support the two ends.
Thanks.
Clive
  • should be fine.
    A spiral wrap wire  is the usual, in such a way that the SWA passes by the anchor with gentle bending.
    The thin ones for BT are called 'curley wurley' by the wiremen. The formal titles are wire grips.
    At a push it is possible to make one with a coathanger.
    Or a cable tension sock
    And a couple of hook plates.
  • Clive,
    An overhead span of five metres without intermediate support would sound reasonable, given that the SWA should take the load in similar manner to the steel support strands in CW1411 and is mechanically more substantial.
    What sort of diameter is CAT6 SWA over the sheath?
    I might have a few BT Clamp Dropwire 10A hiding somewhere that you can have, but being designed for CW1411 2-pair dropwire, they only properly clamp cables up to about 6 mm diameter.
