Sparkingchip:
Maybe the saving grace is that bonding is more effective in reducing touch voltages in TT installations than in TN installations.
Andy Betteridge
In the GN it actually says:
13.2.1
The effect of applying main protective bonding is most noticeable in TT systems
Sparkingchip:
The house that Dave is asking about was presumably installed as EEBADS without any RCD protection in the consumer unit or fuse board at all, indeed it is still possible to install some circuits in homes without RCD protection, though not lighting circuits anymore as they require RCD protection as of this year.
gkenyon:
weirdbeard:
Hi John, BS 7288 wasn't listed in appendix 1 of the 2008 17th edition, and here is a related topic from ye old forum:
https://www2.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=28346
Would you mind explaining why this has fairly recently become an issue that you hold dearly? ps, you seem to be struggling to get your new board fitted, I have a couple of hours spare next week if you need any help :)
BS 7288 itself has been updated.
The current version of BS 7288 does not have the same provisions as the previous version, and, in addition, attempts, perhaps somewhat clumsily, to interpret BS 7671 using a mixture of terminology ... and further clearly says that additional protection must already be present in the circuit in which it is installed.
So, this isn't just BS 7671 we're discussing here, but the product standard itself.
Pat Eardley:
BS7288 products have improved their testing standards but still do not match the standard applied to BSEN 61008.
Quite why it has taken 30 years to have the blinkers removed on this subject, despite questions through the ages, is beyond me.
A big shout out to John Peckham for his valuable insights.
Having said that, I wouldn't want to see a decline in use of SRCD's.
