Solar panel inverter protection unit.
A chap posted a question on Nextdoor asking what a “solar panel inverter protection unit” is.
I said I do not know, but I would enquire. Here’s his explanation of what happened:
”Good morning Andrew, I was cold called to say that my System was due a health check due to it's age as it was about to run out of the Warranty period. At that health check the person explained that the Inverter's were the most delicate part of the system. Then I stooped understanding the explanation. He said that the instillation of an Invertor Protection Unit would solve the problem and extent the life of my system ind improve efficiency”
comments please.
Andy Betteridge
  • An element of snake oil I suspect.
    It may be that they are really selling a surge arrestor, but it will only extend the life id there was going to be a surge problem
    Otherwise, the most useful thing you can do to prolong the life of an inverter or indeed any electronics is to make sure it runs cool, and is not in a loft that over heats with air vents covered in last years christmas decorations.
    Outdoor wiring and sealing at cable entries probably benefits from an inspection, but that is not buying anything.
  • My thoughts were a surge protection device in an enclosure with a fancy label on it.
    Andy Betteridge
  • A friend of mine had solar panels installed; later the installing company went bust. She then got a call from a company who claimed that they had taken over the maintenance of the inverter to maintain the warranty and that they would do a free annual inspection on behalf of the inverter manufacturer. Said friend booked a visit, an "engineer" inspected the inverter and said that the green light indicated a fault and the inverter would need replacing (for a fee). Friend asked me to have a look. The green LED was just the normal "everything ok" indicator.
