Arran Cameron:
This should be a walk in the park for a good electrician...
How would you wire up a dual RCD consumer unit with the following circuits:
Downstairs sockets (32A)
Upstairs sockets (32A)
Kitchen sockets (32A)
Outside socket (16A)
Inside lights (6A)
Outside lights (6A)
Cooker (32A)
Central heating boiler (16A)
davezawadi:
I would seriously like everyone to stop this effectively futile discussion.
ebee:
(Notwithstanding I am a frontender - back from the days that was all there was back then!).
If kitchen is downstairs as it often is, then kitchen and downstairs sockets on one RCD, upstairs sockets on the other, lights inside on one of them and lights outside on the other.Cooker with upstairs sockets. So far that`s 2 x 32A circuits on each RCD and 1 x 6A on each.Boiler (assuming a wet radiator bog standard central heating type not an electric boiler) on one RCD and outside sockets on other. I`d prefer 2 x 80A RCD rather than 63s. RCBOs if two then cooker and boiler. A cooker, even new, can be leaky. A boiler then RCBO would mitigate a fault on any other circuit causing boiler fail (you`re away on holiday and your pipes are frozen). Although if I had two more RCBOs then outside lights and outside socket - say damage causing water ingress. Of course I`d prefer inside lights to be split to two circuits so RCD split could be up sockets with down lights and vice versa. Breakers would be largest near RCD and inside lights at one end if possible (some consumer units have RCDs at opposing ends so the last MCBs end up in the middle nearest to each other though). My preference, as always, would be RCBOs each circuit. Usually allow the customer to conclude this option by gentle mention, therefore it becomes "their idea" not mine.
This is a real house and an electrician wired the CU as follows:
RCD 1
Cooker (32A)
Outside lights (6A)
RCD 2
Boiler (16A)
Inside lights (6A)
The inside lights circuit was later moved to an RCBO.
