"17 edition"consumer units still being sold.
After watching a webinar describing the dangers of using dual rcd cu,s with type AC rcd supplying dishwashers,induction hobs etc,
I was wondering why,more than 12months after 18th came into force,they are still for sale.Thanks for any opinions.
        Regards,Hz
  • I stopped using Type AC RCDs a number of years back.
    I can get Type A RCDs (certainly at least the RCBOs if not the RCCBs) at the same price as the Type ACs were. Really it's a bit of a no brainer.
    An EVSE installation recently without 6mA DC leakage protection necessitated a Type B RCCB. Obviously that was substantially more expensive.
  • AJJewsbury:
    I am awaiting a comment from the observant.
    Symbols for the A and AC types are the wrong way around?
    That will be it!
    With an existing Crabtree split load consumer unit that has a Type AC RCD I intend to move the utility room socket circuit onto a new Type A RCBO with a switched neutral to protect the washing machine and replace the lighting MCBs with the same just to add RCD protection, then leave it at that.
    I cannot see the need to replace the consumer unit to provide Type A RCD protection to every circuit, is the existing Type AC really that bad?
     Andy Betteridge
