Microwave Ovens and Internet Speeds.
Stuck at home? Is this true? Will using your microwave oven slow down internet speeds?
https://www.bbc.co.uk/news/business-52027348
  • Only if you're using WIFI rather than a cable to connect to the router. Similar frequencies I guess.
    regards
  • I think another myth, but why would you put your router beside your microwave? ?
  • Chris Pearson:
    So that they do not have to shout to each other across the room when they have a chat.
  • I think it is true the frequencys used are similar routers are on 2450 Megacycles and microwaves on 2500 Megacycles or there abouts the problem I think is that microwaves radiate noise which de senses the router. The cure? Microwave in one room router in another or at the very least the other side of a wall
  • Microwaves operate at precisely 2450MHz, the guard band around it was why the frequencies were clear for unlicensed wifi. If your microwave is not leaky, there will be NO effect.
    I've confirmed this by putting the router ON the microwave (vdsl connection, 79.9Mbit down). Microwave on, and off, speed test gave the same results.
    Ofcom are talking cobblers.
  • How about the other way round, where you put say an iPad or lap-top near the microwave oven door. Can it still communicate with the router?
    With the Microwave Oven Off, wonder if the door screening is sufficient to stop an iPad ect from communicating with the router (outside the oven)?
    Clive
  • Some microwaves are quite leaky, I have seen effective radiated power of tens of milliwatts, and also some folk try and stretch their luck with 2.4GHz WiFi. If you have a rock solid connection with 60dB of excess signal to noise ratio and  / or the door seals are in good condition, you will not see any effect.
    Equally folk hanging on to near drop out levels of RF, received signals of -80dBm or less (that is 1 milliwatt divide by 108), will find it falls over at every small disruption, and a microwave with imperfect door sealing could be that - some designs  are quite a wide band jammer, as simple power supplies mean they have a strong a few hundred MHz of FM sweeping in time with the mains frequency.
    The maximum permitted leakage  specified in EN 60335-2-25 is 5 mW/cm2 on a receive antenna at a distance of 50mm from the surface of the oven (mW/cm2 is the power present in one square centimetre measured in milliwatts).  After a few years of having the door bashed about, some do not quite meet this limit near the doors, most are much quieter round the back and sides. Generally signals expand cone like, so the no of mW/cm falls off with the square of distance, but then so does the signal from the router - which is why it is 10 orders of magnitude weaker at the other side of the house than near the transmitter, and of course why we use dB relative to a milliwatt, and generally the nearest few of them. If a radio signal has not doubled or halved in power for no good reason during a fixed link, it is probably not real radio.
    Of course a reliable fibre or twisted pair back to the router is not affected like this.
    A similar consideration applies to  ADSL which is fine in town, but becomes far more 'flakey' if you are far from the exchange and have a lot of overhead feed both picking up and radiating on medium wave,
