Fultonius:
Obviously the wiring from the house to the garage (at the bottom of the garden, so maybe 30m of wire) is a bit underspecced for what I need. Upgrading this would give me more chance of getting the correct voltage, and would probably make sense if I plan to put any "unused" power back to the grid. If the panels/inverter were grid-tied, what voltage would I end up with in the garage while running the roaster? My assumption is the amps will flow from the inverter to the roaster, and the grid will not have any effect? However, that's where my concern is - if my local voltage is higher, will that then default to pushing back to the grid and pull my voltage down?
I'm not sure that last sentence makes any sense. While the solar panels are generating, it will always pull up the voltage at the shed. That could be either because the inverter is pushing current out to the grid (so the volt drop goes the other way), or at least reducing the volt drop because it will take some of the load and reduce the amount of volt drop.
Bear in mind that solar panels only work well when it's sunny, and when the sun is shining directly onto them. They do generate on cloudy days, and from indirect sunlight, but it will be a lot less.
It generally isn't recommended to do a solar install at the end of a long cable. You end up losing a significant amount of power warming up an underground cable, rather than doing anything useful with it.
What I really want is to use fill the batteries during the day when our loads are low, and use them in the evening (induction hob, washing machine etc.) when the loads are higher - peak shaving.
