Hi all
I have a large 6kw water heater to connect at a farm for washing a bulk milk storage tank. It is made made by Cotswold heaters and consists of a large insulated tank inside an outer steel box. It is controlled by separate control box containing timers and a contactor and connections for solenoids and a float switch. In the heater itself it is prewired to some din rail mounted style connectors to then accept the incoming cables. The prewired cables from the block to the heater terminals are heat resistant and the other smaller cables to the solenoid and float switch appear to be so aswell. My question is should the incoming cables be heat resistant as they don’t connect directly to the heater element terminals. If it was just a standard heater I would use a single heat resistant flex but there are control cables aswell with just a single cable entry to the heater so I was going to use flexible conduit and singles from the control box to the heater. I have wired a few of these before this way and the cables have been ok years later but in the spirit of bettering my methods I was wondering what way others would attack this job. Would some heat resistant sleeving over the singles at the heater End suffice or where should the requirement for heat resistant cables begin and end? See picture of heheater, sorry about the quality. The heater is at the bottom and connections are all behind the clear Perspex cover, hopefully the picture explains what I’m on about
