Sparkymania:
-2400-
As wallywombat pointed out I made a mistake so the accuracy in this case isn't relevant. It makes sense that my first instinct when it tripped was right about why it tripped. I then done the calculation but my calculation was wrong misleading me into thinking it shouldn't have tripped.
Actually I would turn that around. I didn't bother to check your calculation as there is no point until we know the data going in is accurate.
Having said that, wallywombat posted while I was still typing. I wouldn't have bothered if I had seen his first, as you are now happy.
Kelly Marie:
Hi Sparkymania in your post at the beginning you say that 1.26 Is ok for B32 not B16 what do you mean by that surely if an RCD trips at around 30 mA then it doesn't matter what it's overload rating is? I'm not arguing with you I just would like to understand what you meant
Hi Kelly Marie
I actually said "1.26 too high for B32 but okay for B16" not the other way round but maybe that's what you meant to say but typed it the wrong way round.
You're right. By the time I was writing that last post I was so knackered that I was having trouble thinking straight. The RCD would have covered a high Zs.
However, the circuit was changed from a ring to 2 radials and therefore needed the B32 changed for the spare B16.
Like I say, I was half asleep when I typed that last one but wanted to respond to the last poster.
