Burying SWA
hi guys, just looking for a general consensus on the depth to burying SWA in a garden area which would be expected to be maintained by gardening forks and spades etc, I intend to line trench with sand and lay marker tape approx 150mm from the surface, what depth would be acceptable, I'm edging for 600mm total depth
  • Depends on the exact circumstances - flower beds generally are cultivated to a shallower depth than say veg plots for example. But I normally go at least 500mm deep.
    Where the soil is cultivated I don't bother with tape just 6" deep though - it wouldn't last a season - but I put an extra run a few inches above the duct.
  • Sounds about right. Historically 2 spade height depths which equate to 24" or 600mm for metric depths.
    This is guidance from, if I remember correctly, the OSG and GN1
    Legh
  • and very close to surface under concrete paths that are unlikely to come up before the wiring. Seconded that your 60cm idea is about right for a normal garden. Not perhaps enough for ploughing or if the erection of marquees with steel spike pegs is expected
  • 12" is big for a garden spade and routine cultivation would be limited to one spit. However, when planting a tree or shrub, even in an established bed, it may be necessary to go deeper. 600 mm for the cable is plenty.
  • I think 1m LV cables (deeper for HV) is recommended and suggested route is around the periphery.
    There is guidance for this somewhere.
    I do remember being in a large garden when a 3-phase underground supply cable was extracted by 'digger Pete' with his hydraulic bucket.
    That was quite ammusing when he pronouced himself on the phone to Western Power to explain his reasoning for the trench.
    Legh
  • Is an alternative to keep it visible, i.e. along the fence line at a couple of inches above ground level?
