Baldyhugh:
Does anyone know why the solid and flex sizes are shown in metric but the stranded are shown in American sizes? May seem a stupid question but does that rule out using European stranded cable if they state awg sizes?
Where did you see that? In this data sheet: https://www.wago.com/gb/products/datasheets/Data_Sheet221-412_16.12.2020.pdf?product=221-412&lang=en both systems seem to be quoted for all types.
whjohnson:
Having been late to the WAGO party I have only recently begun to use them. Uncertainty was introduced recently when conducting r1+r2 tests on a ring final whereby the socket fronts were substituted with wago grey with orange lever types for test purposes. The test readings end to end were wildly different, so much so that I shorted 2 ends at the board into the earth bar and went back socket by socket to test the end to end at each. I got steady and constant readings that way, so can only conclude that the wagos were a bit hit and miss.
I am surprised. Did you substitute the Wagos for the sockets 'cos they had USB port-saïd you needed to IR test the circuit?
ETA: see what a mess my smell checker has made of "ports and"! I haven't been there since the First Gulf War. ?
Chris Pearson:aligarjon:
I only use the levers if i am connecting a flex as i have never been able to push one into the standard Wago without it just bending over. If you need to get a smaller cable out of the standard Wago without destroying it, so maybe to test. If you push another core of the same size up along side it will pull out with a gentle wiggle if you are careful (I have only tried it with 1.0mm)Yes, I don't think that the ordinary ones are intended for flex, but there are the straight through ones for lighting with a sort of push button for release.
I have just tried the second wire trick. It worked for 1.5 mm² and 1.0 mm², but the second wire tends to catch! However, if you use a scrap for the second wire, it can suffer a bit of abuse when you pull it out. 2 x 2.5 mm² doesn't fit. Another good tip! ?
Funnily enough i only discovered it by doing the 'pull test' after trying to fit 2 conductors in the same terminal , :)
Gary
