Nu Heat wireless UFH.
I have picked up a job started by someone else with Nu Heat UFH which is to be controlled by using a mobile device through the hub.
I wired the wireless room thermostats to the floor sensors and left them without the batteries in them so I could power them up for the first time when the plumber completed the plumbing so the whole system could be commissioned in one go.
The customer jumped the gun and put his own batteries into the wireless thermostats as he didn’t know where I had put the supplied batteries and linked the hub and stats to his phone.
The wireless control box is not linked into the system, I presume I now need to disconnect the hub then do a factory reset on the room thermostats to make a fresh start as at the moment I cannot even access the set up menus on the stats, then having kicked his phone out set it all up again on my Ipad, then when it’s working hand the working system over to him.
But if I set it up on my IPad will it make me the system administrator forever and stop him from having full control from his phone? Should I actually use the customers phone to set it up?
  • More over complicated modern unnecessary stuff. Why the 'ek would you want to control your heating by telephone.  Just chuck a log on the fire when you get home.
  • Zoomup:
    A timeswitch works well enough for me, but fairly obviously if your working hours are not regular, you may want to be able to switch on say when you leave the office.
    Chucking a log on the fire works only if somebody has lit it in advance. ?
    In answer to the OP, I have no experience of these systems, but using the customer's 'phone seems to be a very sensible idea.
  • Chucking a log on the fire breaks the radiants ?
    On this particular job the customer cannot walk to a switch or a controller on on a wall.
  • Looks like rebranded Heatmiser so just set up the hub and down load the app and follow the instructions.
  • Time clocks and roomstats are like using carburettors and distributors for cars. The world has moved forward honest.
  • Chris Pearson:
    Zoomup:
    It is good to return to a cool home rather than a hot house as.
    1. You have saved energy.
    2. You have saved money.
    3. You will appreciate the smaller temperature rise more when the heating is actually turned on.
    4. You have reduced emissions.
    5. You will help to save the planet.
    6. Eventually you will rise to Heaven, but not due to hypothermia.
    Laying your old scrunched up fish and chip newspaper wrappings in the fire grate, with dry kindling above, needs only a match to get it going before you chuck on the log.
  • I reset the thermostats with the hub turned off, ran through the setup and got the system running off the wireless stats without loading the app onto my phone, then booted the hub back up and confirmed that the customer can control the system from his phone.
    So I completely avoided connecting the system to my phone and having to pass control of the system over to the customer.
