Caravan hook up
Hi I am fitting a caravan hook up on the wall next to  the dno incomer box. No wires exposed. Do I still require an earth rod. The earth bond will be prob 1 ft long inside so not exposed. I know if I fit the box away using swa then yes earth rod would be used.
  • Sparkingchip:
    Then throw into the mix that whilst camping I have seen motor homes and caravans with two leads supplying them from two 16 amp site supplies at the same time.
    One of my first thoughts when I saw one such arrangement using two pillars on separate pitches was that there is an assumption they are on the same phase, that’s assuming that the motor home users even realise that different pitches may be on different phases when they are running out the extended second extension lead, heaven only knows how the leads are connected internally within the motor home.. ?
    If internally each inlet goes to its own CU, is there a problem if the outlets are on different phases?
  • Sparkingchip:
    gkenyon:.
    In truth, caravans should not be plugged in at homes with PME earthing arrangements.
    From my front window I can see a motor home plugged into an extension lead running from within a house, it’s connected to a PME supply, via a Type AC 30 mA RCD in the consumer unit. I know that because I fitted the consumer unit around ten years ago, long before the neighbours bought the motor home.
    A socket is a socket, what’s the issue? Why would a caravan or motor home user question plugging it into any electric socket?
    I agree they wouldn't ... but it's still the DNO's responsibility, under Regulation 9(4) of ESQCR, to ensure this doesn't happen ... and not a "so far as reasonably practicable" legal requirement either:
    (4) The distributor shall not connect his combined neutral and protective conductor to any metalwork in a caravan or boat.
    And I have to also agree ... why is an EV different to a motor home different to a caravan etc?
    Although, a caravan in a field is a very different situation to a caravan on an urban driveway.
  • gkenyon:
    However, I can confirm that it doesn't matter how quickly technology moves on in this particular instance. Unless and until the relevant legislation - Electricity Safety, Quality and Continuity Regulations - is revised, BS 7671 (and any provisions or guidance from ENA or DNO's) will never allow the connection of a caravan outlet to the earthing terminal in premises supplied from PME, quite simply because Regulation 9(4) does not permit an electricity distributor to connect a PME earthing terminal to a caravan or boat.
    I am going to be a little mischievous and ask what penalty a consumer might face when he plugs in his caravan, be it in the driveway or elsewhere.
    I feel sure that para. 4 of R. 9 forbids a distributor from installing a PME supply into a static caravan where it may be reasonable to install a service head, etc.; as opposed to a touring caravan, which by its very nature needs to be able to unplug.
    R. 35 makes a distributor who has failed to comply with ESQCR 2002 liable for a fine of up to level 5, which nowadays means unlimited; but a consumer's liabilities are limited. R. 34 allows the Secretary of State to require that "any part of a consumer’s installation which is not enclosed in a building ... [which] is or is liable to become ... a source of danger to others ... shall not be used; or shall be made dead; or shall be removed ...". So when Mr Sharma goes canvassing in his constituency, what will he do about all the caravans that he finds "hooked up" to a socket on the wall?
  • Or parked out in the road with a flex trailing across a public footway?
  • Sparkingchip:
    From my front window I can see a motor home plugged into an extension lead running from within a house, it’s connected to a PME supply, via a Type AC 30 mA RCD in the consumer unit. I know that because I fitted the consumer unit around ten years ago ...
    Well that's all right then. ?
  • Interesting combination.
    https://www.ebay.co.uk/itm/154016689192
    The reality is in all fairness people do not know that connecting there caravan this way is breaking regulation. A static with an earth rod I can understand as its connected within the unit. Its odd that a caravan hook up in a field with a rod yet the caravan will have a flex wire I think from. Memory is 25m allowable away from the hook up. But going back I have friends that have motor homes caravans all plugged in at home. Some people will say they should know its there responsibility to know, well if it was that bad leads should not be sold openly on the market. From all my posts about this I see that it is a hot potato with many differant takes. I want to get mine up and running at home but putting an rod in is not practical at my property so I have to find another solution. For me it's very odd that the regs can rush through an amendment for ev chargers but the mobile motor homes and caravans very simular set ups have no changes to regs. As I am sure that an ev pen fault technology out now to use with ev chargers is the same solution needed to resolve this issue with home installs for the leasure industry but as pointed out previously to me unless it has been granted by the powers above its stuck with the regs we have now.
  • I shall play devil's advocate.
    In what way is this suggestion different from hundreds of items of street furniture? I do not see that it is, and they appear to present no danger at all. Is this just a throwback, never corrected, in the ESQCR and BS7671. Typical Earth resistance for lamp posts and phone masts is still 100 ohms or so, in my view very dangerous with a PME supply.
  • Chris Pearson:
    Well, I'm not a lawyer, but I'd have to say none, because the obligation is on the distributor.
    I think that the distributor may have the powers to require the consumer to not connect a caravan on risk of disconnection ... but of course, if it's a plug-in unit, then I guess that's not going to be easy to resolve, meaning it's easier to let it go.
    As for the other assertions regarding static caravan etc., the original DTI Guidance on ESQCR 2002, in its commentary on 9(4) - see Page 20 - does not make the distinction, and talks about all caravans and boats.
  • davezawadi (David Stone):
    It's probably not. Again, this is discussed on Page 20 of the DTI guidance I linked to in my previous post, and there is special consideration in G12/4 for street furniture on PME.
