Small time electrician
Hi.
I’m a fully qualified Level 3 electrician (C&G 2357) and have completed my AM2, 18th edition and everything. I work at a large college, but mainly doing reactive work and small repairs.
I have two questions...
Firstly, I am a small time electrician also, working for friends and doing small jobs (generally minor works and repairs)
Do I need to be registered with one of the main bodies to sign off my own work? I'm sure it has been asked before, but there is no definitive answer.
Secondly, Do I need to go through C&G 2395 Inspection and testing in order to carry out my own IECR’s?
  • First, anyone can sign an EIC/MEIWC - it is just you declaring that in your opinion, you have the skills and experience to have carried out the work well, and that the work compiled with BS 7671: 2018 except where noted.
    But...
    Some types of domestic work are notifiable to the local authority Building Control under part P of the Building Regs - principally, adding a circuit, replacing a CU, or bathroom work within the zones (in England anyway). This means either: the house owner has to fork out in the region of £200-£400 for BC to pre- and post-approve the work, or pay for a 3rd party electrician to certify it (not just any electrician is allowed to do this), or thirdly (which is what most domestic electricians do) join a Scheme, prove to the Scheme that you are suitably qualified, pay large fees, get regularly assessed, then you can self-certify your work to BC for  nominal fee.
    Furthermore, especially if you charge for the work, then the Electricity at Work regs may kick in, imposing some legal obligations on you. And you would want to be insured, and be confident that the insurance company agrees you're competent so that they will actually pay out if someone's house burns down as a result of your loose connection.
    Finally, there is the general duty of care in law - even if it was unpaid work and not notifiable, you might find yourself on a manslaughter charge if someone died as a result of your allegedly negligent work. This is one reason why not everyone who can sign an EIC should.
  • Andyy:
    No, it is not compulsory, but I would certainly put it in the "desirable" column of a person spec. If you can get your employer to fund it as CPD, that would be great.
    Regarding insurance, you ought to have professional indemnity insurance for I&T.
    So pretty much join a scheme.. I think that is the answer... Thanks!
