ebee:
Thanks Graham.
Yes I only did the bog standard 2.5/1.5 calcs.
Thanks Chris 36% eh sounds big but if you`ve done the sums then that is an eyeopener.
My initial indignation was the term "exactly" being bandied about in such a manor.
6% didn`t cause much concern because the numbers are small to start with. Whereas 36% is a different ball of wax
I don't get 36 %, but 20 % ... but of course that again, as you say, is a different ball of wax.
Basically, the rfc test only yields (r1+rx)/4 at every point, for conductors of the same csa.
Chris Pearson:
I still wonder why anybody would use 4 mm² T&E for a ring.
Minimum tabulated current carrying capacity Iz to be at least 20 A (Reg 433.1.204) and therefore from Table 4D5, Ref Method 101# or, where correction factors (such as grouping or ambient temp) might mess things up a little, Ref Methods A, 100#, 102#.
As per earlier comment re 6 sq mm .... you might struggle with some products to drop spurs off a 4 sq mm ring at a socket-outlet or other accessory to BS 1363 because of terminal constraints if the product meets the minimum requirements of the standard.
gkenyon:Chris Pearson:
I still wonder why anybody would use 4 mm² T&E for a ring.Minimum tabulated current carrying capacity Iz to be at least 20 A (Reg 433.1.204) and therefore from Table 4D5, Ref Method 101# or, where correction factors (such as grouping or ambient temp) might mess things up a little, Ref Methods A, 100#, 102#.
Graham, thank you. I see what you mean. I had thought do radial instead, but short of going up to 6 mm² (which as you say, is possible only with the better makes of socket) under those circumstances, it would be necessary either to downsize to a 20 A OCPD, or complete a ring.
