High Voltage Ioniser
We are using a high voltage (Pulse AC ±7000V) ioniser bar from Keyence on a machine? Would this need to be wired through safety contactors so when an interlocked door is opened, power to the ioniser will be cut off.
  • Can you touch the ioniser electrodes in this case?,
    and if you can, does the voltage drop below 50 V when you connect a human in this way ?
    If yes and no, it needs a door or access that needs a tool to open.
    IF no and anything, or yes and yes, then it needs no special precaution.
    This is much the same as you can have a 10kV electric fence at the side of the footpath, but the current must be limited, so the voltage collapses if too low an impedance is connected.
  • Thanks Mike, I'll need to contact Keyence in that case & find out if the electrodes are accessible or not. I don';t think they are.
