Problem is that even if those plumbers have heard of diversity, they probably think that it means that you have to genuflect at the start of a game or race. ?
I don't think that I would apply diversity to a normal basic fixed load shower. It can probably be set at half load or full load with two sets of heating elements. I would rate it at full load Amps. for cable sizing. The previously mentioned all singing all dancing electronic shower automatically adjusts the load current I believe, according to the incoming water temperature and the water temperature set by the user for comfort. So in that case things may be different in practice, but I would still chose a supply cable based on full load current.
AJJewsbury:Clipped direct includes cables installed on brick walls with or without capping covered in plaster
Indeed. On the other hand most shower cables run through a floor void at some point - that's method B - now what does a 6mm² look like?
Will 'cable installed in a ceiling' in section 7.2 of Apdx 4 also apply if there's no junction box, just the cable in the ceiling, that refers to RM A?
Farmboy:AJJewsbury:Clipped direct includes cables installed on brick walls with or without capping covered in plaster
I believe that the junction box heat concerns apply to heat created by a luminaire, such as a tungsten filament lamp. Sometimes a junction box was situated close to or by a hot luminaire.
Table 4D5 is for use with cables at 30 degrees C ambient temp. and conductor operating temp. of 70 degrees C. You could warm your hands on a winter's day at 70 degrees C. The old fashioned big brown circular junction boxes that I use won't be adversely affected by a warm environment or catch fire.
Zoomup:Farmboy:AJJewsbury:Clipped direct includes cables installed on brick walls with or without capping covered in plaster
Will 'cable installed in a ceiling' in section 7.2 of Apdx 4 also apply if there's no junction box, just the cable in the ceiling, that refers to RM A?I believe that the junction box heat concerns apply to heat created by a luminaire, such as a tungsten filament lamp. Sometimes a junction box was situated close to or by a hot luminaire.
Yes but if it's acknowledged that cables in a building void (such as in a ground floor floor void) are RM B, then should RM A be used for cables in ceiling/floor voids (such as between flats) even though there may be no JBs, just the cable in the ceiling void?
Farmboy:Zoomup:Farmboy:AJJewsbury:Clipped direct includes cables installed on brick walls with or without capping covered in plaster
It seems to be an engineering judgement call based upon experience. I can't imagine a shower cable getting too hot and becoming damaged for a short shower use of say 10 minutes. J.B.s are not an issue here.
