Chris Pearson:
Selecting some sockets is not the same as sampling them.
Any sample should either be random (I doubt that happens very often) or state how they were selected.
I think that we all know that the same selection should not be inspected time after time.?
We never normally select the sockets behind large heavy appliances like washing machines or tall fridge freezers.
kfh:
When my daughter bought a new (old) house I did an inspection of the electrics. All was well and I remember removing one particular socket (brushed chrome) and the connections were OK and tight so I refitted it.
A couple of months later she commented that if she used this particular socket it tripped the RCD. I found a screw had fallen out (it was in the back box) and the innards of the socket were loose as a result, which cause a short when a socket was inserted. It was a very cheap socket brand. I suspect the MCB also tripped but she was a bit vague about it.
How far can one go with an EICR.
As far as is reasonably practicable. At least in most cases of faults the protective devices do their job well.
kfh:
That's the problem with disassembling things in order to inspect them. So having done your walk around, do you inspect the innards of the dodgy looking sockets, or do you leave them alone for fear of making things worse? ?
Chris Pearson:
Also, sampling where the sample population is less than 100 is not valid.
