mapj1:
Ah yes, Eric's lecturing style was something else - he really did understand it.
You do need the free time to let it soak in to fully appreciate all of it.
Professor Laithwaite is a wonderful lecturer and demonstrator. The video clip is fascinating. Thanks.
Foucault currents are the currents induced in masses of conducting metal that are immersed in a variable magnetic field or that, in motion, through a constant or variable magnetic field. In any case, it is the variation of the magnetic flux that generates these currents. The phenomenon was discovered by the French physicist Jean Bernard Léon Foucault in 1851.
mapj1:
We can call eddy currents that if you like, but please note, it is not currents that the lines on your diagram represent.
The lines in the diagram are magnetic fields, quite a different thing, and at right angles to the current.
Both the driving currents, and any induced Foucault currents associate with those lines of magnetic field are entirely out of the plane of the screen.
* (magnetic field lines tell you the pointing direction of an imaginary small compass, lines of current are about moving electric charges . This was not fully fixed in 1898 you may do marginally better with Electricity and Magnetism by Bleaney and Bleaney 1957 vol 1. however it is not a light read.).
Yes Mike I know that the lines are magnetic "flux" or "field." it is these that create the unwanted eddy currents that can cause problems and energy wastage. My McKenzie Smith & Hosie book of the 70s entitled Basic Electrical Engineering Science says: "If a loop of conducting material is linked by a varying flux, an E.M.F. is induced in the loop and a circulating current will flow round the loop. The current in the loop is termed an eddy current. The eddy current flows around a path of one turn which is effectively a short circuit. "I am not disputing the arrangement of the parts of this process. The film about electromagnetic waves was very interesting. Thanks Mike.
