Crumbling Choc Block!
Evenin' All,
 A first for me today. Never before seen. I was removing an old brown three terminal choc block that had been recessed into a very old lime mortar brick wall inside a house. The cable ran to an outside high level light. When I removed the choc block it just crumbled like seaside rock. I couldn't believe just how brittle it was. It was only supplying a single outside light mounted on a wooden back mounting block. No overheating evident.
P.S. Add. The outside wooden mounting block for the light was screwed to the outside wall. The installer was a boat builder so the wood is probably marine grade "teak" or similar. Could the wood have given off fumes that worked their way through the hole in the wall to the chock block insulation and attacked it?
The cause? Chemical reactions?
Ideas please.
  • Now off on a tangent.....
    Teak oil spontaneously combusts (mywriterscircle.com)
  • how old - the very early choc block, the stuff that actually snapped like chocolate, was Bakelite, and so hard and brittle, but nor crumbly.  I am wondering about some rubber formulation, or maybe some sort of thermoset cast resin. But by maybe mid 1960s it would all be nylon or polyethylene, for reasons of cost.
    There a no readily available chemicals that turn nylon crumbly, but  the effects of various agents on different plastics are summarised here
  • mapj1:
    Yep, the stuff is very hard and brittle. I am used to the strength of Bakelite, this stuff that  came I across is 20 times more brittle than Bakelite. It cracks when you just look at it.
  • My experience of Gt Yarmouth or Cromer rock is that it is, er, like rock. It doesn't crumble.
    I wonder whether this choc block was something like vulcanised rubber - it does not have to be soft like a modern tyre.
    The wood will have had nothing to do with it.
  • Zoomup:
    Don’t you know about the dangerous napkins and tea towels in Indian restaurants?
    https://www.bbc.co.uk/news/uk-england-nottinghamshire-42988170
    Don’t save oily rags in your garage, workshop or van.
  • Sparkingchip:
    Zoomup:
    Blinkin ek!
  • Zoomup:
    However did you measure that?
    Jaymack
  • Jaymack:
    Zoomup:
    Jaymack
    Empirical experimentation Jaymack. Empirical experimentation.
  • Chris Pearson:
    The chemical reaction, if that is the cause, must be due to the lime mortar in the wall then.
