For example, 110% of 230= 253 volts. Assuming L and PE are of the same size and material, indirect contact touch voltage is 126.5 volts. Would 0.33 seconds not appear more realistic?
From IEC 61200-413
mapj1:
Well, being old enough to remember 1981, though not old enough to vote at the time...
... in the same way we had folk telling us not to include the area of the lawn in the 100m2 served by the ring, even if the socket for the lawnmower was say a socket by the back door.
(if you do include the lawn area you find it plays havoc with the diversity and maximum demand sums.)
Chris Pearson:
When I returned from letting out my house circa 1990, the lawn had been tonsured as it were, i.e. the mown area was semicircular. The rest was what we would nowadays admire as a wild flower meadow area. Why?
Presumably the tenant didn't own an extension lead!
wallywombat:Chris Pearson:
When I returned from letting out my house circa 1990, the lawn had been tonsured as it were, i.e. the mown area was semicircular. The rest was what we would nowadays admire as a wild flower meadow area. Why?Presumably the tenant didn't own an extension lead!
Spot on! It was so very irritating, but didn't take long to fix.
Back to Mike's point about the 100 m² area, a lawnmower, or strimmer, or WHY on a 50 m lead covers a semi-circle of about 4000 m².
ProMbrooke:Well, I'm prepared to show my inference in great length, for the world to see, for the benefit of all humanity. :) Hiding the technical reasoning is both a crime and unethical when used to make what is used as law all over the globe. And I know why the IEC has gone into hiding technical aspects: because AFDDs are just the start to a long marketing concept. If you can mandated it, then it will sell. But that is for another thread.
mapj1:
A very similar curve is in the older editions too. However the pinhole breakdown mechanism is thermal, and takes a some tens of milliseconds to occur
That fits well with the experience, starting as a tingle for a noticeable time, and ending with a trip. You're more daring in your sharing (of the standard's figure!) - it's certainly better than my written description.
