Cord Operated Ceiling Light Switch. Pre-Removed Cable Access Knockouts.
It is just too hot to tidy the work vehicle today. I keep putting it off. The insides look like Steptoe and Son's  front room. Anyway to keep to the subject I have bought some replacement cord operated ceiling switches from an infamous online source. The make is PMS. They are rated at 250 Volt 6AX.
They come with all of the rear positioned knockouts on the circular base already removed. There is an elliptical shaped hole in the centre for back entry, plus all of the entries around the base circumference have been left open. I suppose that the design saves on materials. So, no more having to sweep up white bits of sharp plastic from the customer's floor.
I hope that the switching action is reliable, as I have not used them before.
  • Sounds a bit dodgy. I guess they're relying on the mounting surface to complete the enclosure - which presumably restricts it to non-combustible surfaces (526.5).
  • AJJewsbury:
    Indeed, those were my thoughts as well. These are mainly installed on plasterboard ceilings so I can see no real issue here. And how may cord switches do we find catching fire?
    Come to think of it, ceiling roses have a blinkin' great hole in the base plates.
  • Zoom
    If there was never anything which could be knocked out, why refer to "knockouts" rather than just "holes"?
  • Chris Pearson:
    Zoom
    Cos the holes are in the original knockout positions, that makes it clearer for the initiated. If I just referred to "holes" that would not provide a complete picture. Let's call 'em cable entry apertures then.
    AND the cord switches are ASTA certified.
