Measuring current in centre tapped supply
Hi all,
I am wanting to monitor the current to a 110V motor fed from a centre tapped transformer. Total current could be max of 16A, so a CT will be required. My question  is, how do I get the actual current used by the motor? Can I simply put 1 leg through the CT, set the meter to the correct ratio and that's me or am I missing something?
Cheers
  • CT around one of the live cores  is fine assuming it is the classic builders 110V that is 55-0-55 centre earth, as no loads are ever connected to anything other than the 2 outers, the earth is just there for ADS/shock protection.
    Be aware that V.A. is not the same as watts though, VA is usually quite a bit higher for a motor once running.
  • The the fact that the supply is from a center tapped transformer is not relevant. The connections to the motor should consist of two current carrying wires and probably a protective earth.
    Measure the current in either of the two current carrying wires.
    Cheers chaps….was 99% certain, but just wanted to be sure. Many thanks
