Premature collapse of accesories?
Having just fitted 8 x new LED emergency bulkheads I noticed a propensity for the new screwless spring clamp connections and it got me wondering about the robustness of such in the event of fire.
The good old choc block screwed connectors would continue to hold a cable in place despite the plastic outer being melted off and thus hold the remnants of whatever was connected to them. I wondered if the new screwless clamp types would wilt under the heat and thus drop whatever they were connecting to onto or into somewhere it would not ideally be wanted.
Any thoughts upon this?
  • What exactly are you referring to W.H.J? Just what type of stuff is supported by  spring clamp screwless terminals? Are there now ceiling roses of that type for example? Even plastic flex clamps would not be much good in a fire.
  • There are various videos online that show Wago and other spring connector plastic bits melting. Usually the wire insulation has melted first and if my memory is right the spring clamps hang on until the bitter end.
  • I agree - in the ones I've looked at the plastic parts of the screwless terminals are only needed for releasing the conductors (as well as insulation etc of course). Take the plastic away and I would expect all the metal bits inside to still hold together.
