I have a sub main distribution board which feeds the final distribution boards and 10's of individual loads.
Now considering that I have an option of applying both MCBs and MCCBs as the outgoing circuit breakers.
MCBs - Standard ratings are available from 0.5A to 80A.
MCCBs - Standard ratings are available from 0.5A till 2500A.
Can I have a mix of MCB and MCCBs as the outgoing breakers in the overlapping area till 80A? (In otherwords, for loads upto 80A, MCB will be used and above which MCCB will be used).
Note that prospective fault current at the sub main is less than 20kA. At 20kA both MCBs and MCCBs are available.
I'm sure many would have used this configuration. Are there any cons with this arrangement?
