So a DALI system is a ‘smart’ lighting system with different options of setting groups, dimming changing temperature etc.
In a simple Dali system, where a set of of led lights are dimmed is this how it would get wired/connected.
The main Lighting control module (dali) gets fed the incoming supply from local DB. Then the cables connect from the LCM to the indivudal dali ballast of the lights. Then control wires go to the switches and/or PIR sensors. Then the retractive switch can be used to dim the lights?
Does it require any specific swtiches ?
Thanks.
Sam
