Grey Main Cut-Out Gunge.
I saw some strange flux-like greasy type gunge running out of a neutral block today, not much just a little bit.  It was almost like golden honey in appearance. The lady of the house said that the main fuse had been upgraded to a 100 Amp. fuse recently and not to worry after I suggested that U.K.P.N. have a look. The gunge had dripped down onto a B.C. 951 earth clamp below. What could it be? It was definitely coming from inside the grey cut-out.
  • What type of cable feed the N block? - I think some older cables had oil in them.
  • AJJewsbury:
    P.I.L.C. And it is hot here, so perhaps the oil is expanding and being forced up the cable. A good suggestion Andy.
    Ah, reading between the lines, getting uncomfortably close to her ASC
    She doesn't want the DNO to see that her present load was probably underestimated to avoid cost of three-phase upgrade
    A 3000 year old clamp?!!
    BOD
