Is it me?
Changing the markings for UK and NI should now be a problem, as it is now CE marking is often not really worth the ink, there is no real enforcement inspectorate and makers can and often do declare compliance and affix a valid mark without actually realizing which standards they should be meeting, let alone testing to them.
Mainly it lulls purchasers into a false sense that somebody else has inspected it, and they do not need to. This is not true, and this lamp is a case in point.
Sparkingchip:
I thought we had - isn't it a “UKCA” (and UKNI) mark now?
Postponed taking its introduction to January 2023 due to not getting it organised.
https://rcimag.co.uk/news/ukca-marking-deadline-extended-by-a-year
Isn't that just the end of the transition period? I thought it has already started on 1-Jan-2021 - so the UKCA and UKNI marks should already in use - although the CE mark is still, for the moment, an acceptable alternative.
Sparkingchip:
Anyone able to give an example of a UKCA marked product?
There are quite a few out there, but one we've seen recently on this Forum, the MK Logic Plus Rapid Fix double socket-outlet. Have a look at the rear view, bottom-left, you will see the UKCA mark:
Whilst UKCA can be used now, the formal transition from CE to UKCA/UKNI has, however, been put back until 31 December 2022 now (i.e. will be mandatory for products put on the UK market from 1 January 2023). See here:
Now, now Andy J.
It makes sense that the new to market double socket is UKCA marked rather than CE, because it's a product not generally used in Europe and it's new.
I'm not sure how that will work in the countries that do use 13 amp plugs and sockets like Malta.
AJJewsbury:
So it does. Does that mean they can't sell them into NI then?
What's the problem? It has a CE mark below the UKCA mark if you look closely.
CE is fine for Northern Ireland.
UKNI is only required for products that require third-party conformity assessment, the product is to be sold in NI, and where the assessment body is based in the UK. UKNI mark accompanies the CE mark.
Simples (?) ? … well, not very ?
Sparkingchip:
Now, now Andy J.
The CE mark is there too - see previous post. I guess, then, it will be OK for Cyprus etc.
True, I just blew the picture up on a 32" monitor ?
The answer to the original question is along the lines of what I was expecting, so didn't come as a surprise.
There's the whole of Ireland as a potential market, not just the North so the socket manufacturers aren't going to deny themselves access to that market.
