New Part L 2021 requirements for light metering
Can I get peoples opinion on the new lighting metering clause set out below
 New Part L 2021 requirements for light metering:-
 6.61 - General lighting and display lighting should be metered by one of the following methods.
  1. Dedicated lighting circuits with a kWh meter for each circuit.
  2. Local power meter coupled to or integrated in the lighting controllers of a lighting management system.
  3. A lighting management system that can both: i. calculate the consumed energy ii. make this information available to a building management system.
Of course this regulations still has in the 90% sub-metering, but now it looks like the lighting goes beyond this to ensure 100% and not only this on an individual circuit level.
 Might catch people out that aren’t using a lighting control management systems that can monitor consumption so end up having to ensure a separate enclosure full of meters to achieve point A. Looks like risers and electric cupboards are going to get bigger.
  • Or fewer, higher capacity lighting circuits?
  • I wouldn't worry about it, like many other building regs, this one will be quietly ignored unless Carrie withholds marital benefits from Boris unless he continues to pursue her green agenda..
  • as I read it it is only new non-domestic buildings where at least the big ones are likely to have some central management anyway. Small shops and so on will could simply have a small nos of 16A lighting circuits, or go continental and combine lights and power. There are DIN rail mountng meters that I presume would count.
