Warm Air Hand Drier Loose Lugs.
I recently installed a new warm air hand drier at a local village hall. The hand drier was supplied by the hall. When I took the cover off the hand drier I noticed a wire that had come completely away from its terminal. It had a push on "Lucar" type lug fitted to it end that had come off during transit. I found others loose too, and had to remove then and squash then a little with pliers to allow them to refit tightly. Be warned.
Faston Connector - Bing images
The hand drier was a Warner Howard make. Hand Dryer Automatic Electric Commercial PHS Warner Howard SM48 JuniorEconomy | eBay
Oh, and if you fit one of these 1. Leave enough space left and right for the fixing screws and their special tool supplied with the hand drier. The tool looks like a torx driver but my torx set would not locate in the heads of the special security screws. Don't lose the special tool.
2. Note that the cover overhangs the base. So allow for that.
  • They just don`t make things like they used to - there again they never did
  • I'm very surprised at a Warner Howard product being like that. We used to fit lots of them years ago and they were built like tanks.
  • I bet that tanks have Lucar connectors in them too. Grin
  • Yes I remember them well. The model that I came across is probably an economy Chinese made model. It sells at under £100.00.
  • Not a recent one. Lots of screw terminals with shakeproof washers, and lots of things that look a bit like modern wagoblocks, and 38999 connectors of the kind where the crimp tools really cost.  That price tag is not a mistake..
