Good morning,
Hope everyone's doing ok?!!
In a discussion, about this meter, with someone... I know you can give me the correct answer!
You need to click the box, to view the meter, cheers!
Does it have a proper internal isolator?
Thanks... Tom
Good morning,
Thanks... Tom
I would say NO. On some models the lower right quadrant it will have a screw and the iso is behind it. Eitherway a 2 pole isolator would be better as a test point and more importantly it gives a place that you can Lock Off for safe working.
That photo is a bit fuzzy in the key area - I can read the bar code but not the text to the right of it, but if you can tell us what I hope is the meter model no. in the text above the centre seal wire, we can look it up and probably be pretty certain.
(The white screwslot in the body above the RH terminal cover looks interesting - and I hope identifies as one of these LG 5258 series
If so, and only if so, L+G consider it to be an "isolation switch")
