Detached garage wiring
I have a large detached garage which is supplied from the  house via a "garage" ditribution box, underground armoured cable then into a "garage" box containing main rccd / 6a lighting breaker and 26A breaker all installed by an approved / certified electrician.
Can I, as a non professional electrician, considering the new regulations, wire the garage for 3  lighting units , and 4 x 13a doulble  power power sockets, and connect them into the supplied distrbution box without having the instalation certified?
Many  thanks for your replies and guidance on this post.
  • Are you in England or Wales? (they have different rules.)
    If England and you are extending or altering existing circuits, there is no need to notify. In Wales you probably do, unless the wiring is all indoors.
    If you are creating brand new circuits, then in any case they are notifiable.
    If you are competent to do so, you can create your own certificates, but it will be in the gift of your local authority building inspectors to decide if they will accept that. The only folk who can inspect and certify your work, officially at least, are the local authority, or an electrician who is part of a 3rd party verification scheme such as NAPIT.
    NICIEC do not do 3rd party verifications (though some members may 'adopt' the work of others it is not the approved route.).
    But what you propose raises more questions than mere paper trail. Is the existing supply up to it, and why do you need 3 lights circuits at all, and what is currently  connected ?
  • I think that we need more details please. Did the electrician's work stop at the CU? If so, you will be creating new circuits, which are notifiable. However, if you already have at least one light and one socket, you will be simply extending the circuits, which does not require notification in England.
  • Thanks for the quick reply chaps.
    Firstly - in England
    The fitted garage consumer unit is a fairly standard 63A rcd 16A mcb and 6A mcb, previously fitted.
    There are no lighting circuits or power circuits connected to this distribution box.
    The plan is to fit 3 overhead lights to the 6A mcb (all lights will be led fully sealed units over the bench) and 4 x twin 13A sockets off the 16A mcb.
    I am happy to create a ring cct for the 13A sockets to improve available power and safety.
    Reading what you say, if I carry out the work, I will either need to employ a certified electrician to test and provide a certificate or, try the local authority approach which I did not know that that was an option.
    Many thanks mapj1 and Chris that was most helpful.
  • It would be pointless creating a ring if you are connecting to a 16amp breaker. If you are clipping direct in a garage a 2.5mm is good for a lot more than that. About 23 amps i think from memory
    Gary
  • On a 16A breaker, there's no need for a ring.  A simple radial will do.
    When you find out the cost of having the local Building Control inspect the work, you'll probably want to find a tame electrician instead.
  • I am happy to create a ring cct for the 13A sockets to improve available power and safety.
    No need to do that. A radial circuit in 2.5 mm² fits with the 16 A MCB.
    Assuming that you can join up a few cables competently and work safely, the real question is, "what are the consequences if I do not notify?"
    The next question might be, "how do I certify?" The answer is that you can do it yourself, but you need the right equipment.
    Frankly, if it is an average sort of garage in an average sort of property, nothing bad will happen if you wire it up carefully.
  • You may find if you look closely and wish hard, that the original installer left a short cable stub in each MCB, so you can competently modify and extend an existing circuit, ('minor works' if you like) rather than create a brand new circuit, thus sidestepping the whole process. Ahem. (*)
    Who would know if he had or not, and unless you hand yourself into the authorities who would care...Wink Do work safely and verify your work as you go along though.
    PS * yes, this is a real dodge, and of course it is not how the rules are intended to work, but then they are supposed to improve safety and they don't really do that either, rather they keep up the membership figures of some trade bodies and routinely confuse folk at the building control dept who never really wanted that added to their workload either.
  • All noted. I shall look more closely at the garage end in a few days, away at the moment.
    Although not a qualified electrician I have been in electronics, radio, telecoms, repair and installation for 40+ years and still have some test equipment, even a model 8 avo.
    Many thanks to mapj1 / Simon / Chris / aligar jon
