Solar generation meter not working - who can replace it?
I am a domestic and light commercial electrician, semi- retired just doing odd days on my own supporting the local (rural) community.
An elderly lady has been told by her supplier that her solar export meter (installed some years ago out of warranty) has  failed and requires replacement.
I haven't even been to look at it because I am not  registered for solar. However , I've tried to help find a local firm that won't rip her off. The local guy who is registered is too busy, but advised me as its a simple swap I can do this and send the information regards the new meter to (presumably) the DNO.
Is this right?
Where would I start? I don't want to fit a meter and then find I'm stuck in an endless paper chase trying to get the new meter registered against the export MPAN, while this lady cannot get paid for her generation, but neither do I want someone from miles away to roll up and charge her a fortune for un-needed work.
Incidentslly, I recently had solar installed  by a national supplier and it took me hundreds of hours sending emails and on the phone to get  my export MPAN registered ( took 9 months to get paid for generation because they failed to do the notification properly). I don't want to dive down the same rabbit hole again. Advice please.
 Dave T
  • Where abouts are you based?  Probably worth having a look for a MCS certified company or electrician.
    https://mcscertified.com/consumers-communities/
    or call MCS on 0333 103 8130
  • Thanks, but sorry, but that really doesn't answer the questions, or solve the problem of a company coming from miles away and wanting money up front just to look: like I said, rural area.
    Dave
  • Do you mean a generation meter or an export meter?  There's a subtle difference.
    A generation meter is between the solar inverter and the rest of the house electrics, and measures everything generated, whether it's used in the house or exported to the grid.  The generation meter belongs to whoever owns the solar panels and inverter.  It won't have an MPAN number.  It is required in order to claim FIT payments, since they are paid on generation, not export.  If the meter breaks, it's the owner's problem to get it replaced, so that they can start claiming FIT payments again.  If the system doesn't qualify for FIT payments, it's not really needed.
    In most cases, the export meter is simply a register within a SMETS2 smart meter, though it was possible to get a dedicated export meter before SMETS2 meters were commonly available.  An export meter will have an MPAN.  So if you swap it, then the new meter will have to be registered against the MPAN for that supply.  The MPAN itself isn't supposed to change on replacement of a meter; the MPAN and meter serial number are held on a central database.
  • Agreed - just to add if it is the generation meter and it's under FIT, the customer will likely have to have their FIT certificate updated. My supplier insisted I went through that process when they noticed that the original installer had missed a digit off the meter number on the original certificate. https://mcscertified.com/consumers-communities/certificate-queries/ (there's a admin charge too).
  • Thinking about it, if this system is 15 y.o, its almost certainly on the old FIT system so there may not be an export meter. i suppose its possible that the FIT deal may have expired, and what the lady may need is an additional export meter, which i'm guessing, they won't accept being fitted by me?
    Think I'll pop in have a look, and most likely decline the work, as I'm a bit out of my depth here really. If I was 20 years younger I'd have done all the renewables courses I could, i'd have really liked to get involved, but like i say: retired and just helping out a couple of days a week here and there.
  • i suppose its possible that the FIT deal may have expired
    Unlikely - it normally lasts 25 years for PV (and is much better than anything on offer today, so well worth keeping).
    Export meters are like import ones - owned by the supplier (usually implemented as part of an ordinary smart meter these days). There is an option to be paid for actual export - while remaining on the original FIT tariff for generation - and that can pay better than than the export part of the FIT scheme. Have a look for SEG - Smart Export Guarantee. But that's all handled by the customer talking to their supplier.
  • An elderly lady has been told by her supplier that her solar export meter (installed some years ago out of warranty) has  failed and requires replacement.
    How did the supplier come to that conclusion?
  • I bet it was a sales person trying to get creative
  • The only failures I have seen in generation meters is the display,it's more likely to be inverter or isolator(s) mcb,rcbo or rcd related
