Wondering if Wiska KonnektIT are actually safe at their rated loads
I have been looking at these boxes to understand if I feel comfortable using them.
https://www.wiska.co.uk/en/30/pde/10112450/konnektit-204-cl--3x221-413.html
They have a temperature rating of 60 Deg C, 10 below the 70 Deg C the core of a thermoplastic cable can reach. Connections are actually made with wago connectors.
Reading the brochure and TLC web site they are suitable for 1.5mm cable and 32A, clearly we can't put 32A down a 1.5mm cable.
Reading the actual box in very small writing it says 2.5mm cable and 20A, better, but cable core could still be at 70 Deg C.
No instructions supplied but from what I can see but I can't see any way to prevent it being opened without a tool, like other similar products.
I have asked Wiska about the temperature rating and they just came back and said ask NAPIT.
Is it reasonable to assume that the outside of a cable and wago connector would be at least 10 Deg C below the temperature of the core, and therefore in terms of temperature everything is ok?
Bit surprised that a company like Wiska has such poor documentation and am wondering if I have missed something.
Even with my concerns I think it's actually a good solution for bringing together two way lighting connections etc.
  • It depends upon exactly what they mean by "60 degrees". It might mean "suitable for use in an ambient temperature of up to 60 degrees" or it might mean "no internal part may exceed 60 degrees, after resistance losses in the conductors being used"
    I suspect that the first meaning is correct, but does anyone KNOW.
  • Agreed. In that the following line on the data sheet says "Temperatures during install.     -5 °C - 60 °C" - I too suspect it's referring to ambient temperature.
    I guess the patent has expired on the cord grip that MK use in their plugs....
  • I have actually used a couple of these, and I really cannot open them without a small screwdriver to release the plastic catches, so unless unlike me you have long nails that are cut to the profile of a small screwdriver that aspect is likely to be OK.
    It does mean that the enclosure depends rather more on the quality of the plastic moulding than a design with a screw or two would, I guess if you were really  worried a small cable tie could be  added.
    In terms of temperature, I note that the datasheet says it is polypropylene, which  is temporarily softened but not damaged by temperatures up to and slightly  over 100C with a rather indeterminate melting point and is usually injection moulded between 200 and 300C .  Pure polypropylene material data is here   Note also the glass transition - the change from flexible to catastrophically brittle - at  about -18C - it may be possible to use these boxes at -30C, but I think they would be happier being handled and installed at higher temps - allows the lid to flex rather than shatter if it needs a bit of a push.
    There are higher temp versions that have talcum powder blended in, and the tensile strength can be improved if it is reinforced with glass fibre, but as both of these additives make it much harder on the moulding equipment, and looking, these boxes are cloudy but clear, I suspect this is more or less pure PP.
    The fact it passes a glow wire test at 750C should give you some reassurance as well  - I'm sure it melts, but at least it does not ignite !
    Having said that I have used them, in terms of satisfaction, while I was able to do what I needed, and when finished it all looked OK, being slightly floppy it did not have the reassuring weight of a traditional junction box. If you only have 2 or 3 wires there are better things to connect them into. Because of this I'd only want to use them where it was the best option -it is certainly one up on a box of loose bits of choc block however, and there is plenty of room,
  • Thanks all for the responses. It's generally in line with my thoughts. Like you have said for socket circuits with 2 or 3 cables there are better solutions. But I think it's still quite good for the more complex lighting junctions.
