Air source Heat Pumps and Diverted neutral currents
Hi I have been having a conversation around the requirements to fit an RCD on these circuits, it turns out it is a manufactures or appliance standard recommendation. It then occurred to me what out diverted neutral currents if the protective earth & neutral conductor (PEN) were to break.
If these units are fitted on a TN-C-S earthing system and the PEN conductor breaks the metal casing could become live as the earth conductor could end up carrying the neutral current.
The person touching the ground would be earthed and the current would flow through them, in this case an RCD would not function as it wouldn’t see the imbalance. I feel it should be considered its no different to having an electric vehicle charger and having a metal car. For that an Open PEN detection device is required.
Any thoughts on this point ?
Daniel
  • If it's of any reassurance, I've just had a prod around my newly installed heat pump with a multi-meter. The main front grill is plastic, the rest of the (steel) case is heavily coated with enamel type paint and the pipework is covered with thick thermal insulation - the only places I could find continuity were a few small screw heads (none on the front, one on each side and a few at the back). Even the mounting feet seemed isolated.
  • If we multiply up those stats, it's a desperately high number of lost neutral events across the UK each year.
    It's very easy to forget just how badly probabilities multiply up and how nasty things will still happen to other people.
  • The Heat pump 'RCD' problem comes from the way that their controllers essentially have a lowish frequency switched mode drive supply to the variable speed motors which creates near DC current alias frequencies that can blind RCDs that aren't 'designed' to cope.There are German specs appearing that cover testing of RCDs for that duty, but no UK particular specs yet (as I understand it)
    There was some discussion a few weeks ago that's worth looking up. My reply to  Definition of high protective conductor currents discussion on Type B HP RCDs.
