Plug-in Solar supposedly going to be 'easier'?
Hi all, new to the forum.
I've been reading (various media outlets are running with the story) that the government is planning to make it easier (no mention of safety) for consumers to connect solar PV panel inverter directly to the mains using a 3 pin plug and socket arrangement.
Considering all of the current guidance regarding the connection of a solar PV inverter to the mains (dedicated circuit, own RCD, no 3 pin plug), how is this all of a sudden going to be 'safe'?
The argument that 'Balcony Solar' is all the rage on the continent surely doesn't negate the potential risks all of a sudden. Surely the IET is in discussions with government and arguing that the dangers cannot simply be swept under the carpet?
  • so will hard wire my unit into a fused spur
    Which makes it part of the fixed installation and accordingly, subject to BS 7671.
  • ok, for the sake of my G98 questions etc, Lets leave it as a plug in, but still earthed RCBO etc. Whats the answer.
  • Whats the answer.
    Presumably buy the unit then "install" it according to the manufacturer's instructions.
    I'd be wary about blithely bonding the frames etc. - there are some good reasons to do that, but also many good reasons not to - a lot depends on the individual circumstances. Small systems with the d.c. side protected by double/reinforced insulation or PELV/SELV may well not benefit from bonding, but exporting (especially PME) Earth carries risks.
  • Indeed, but depending where it ends up, it may well be earthed anyway.
    It's a bit of a tangent, but there probably needs to be some good practice and EMC guidance created (given the rubbish radiated by a few accredited installations, EMC is not just an issue for DIY kits actually ) for folk who want a reliable installation and or find their solar panels cause interference to their own or their neighbours equipment.
    Silly things like keeping the +- pairs together as they leave the panels and not creating a great loop antenna coupling in and out of the inverter will do wonders both for interference  egress and how well it survives after a nearby thunderstorm. Avoiding situations that could cause currents to be induced or picked up from external metalwork like fences etc. Insulated mounting clamps may actually be better in that regard. I'm not sure of the merits or not of plug in solar plugged in via some sort of filter, but its the sort of thing that should be looked at.
    In terms of poor cable route and mounting onto  things that may import an external earth, a one turn accidental 'secondary' of a few square metres and a 'primary' of a km or so of more or less vertical lightning strike of a few tens of kA a few km or so away can induce voltages easily fatal to semiconductors, even big ones in inverters. Not as spectacular or glamorous perhaps as designing for nuclear EMP, but the physical problems of inducing voltages in remote wiring are similar and can make things weirdly unreliable without an obvious cure.
    My point is that the cohort of new accidental installers who don't realize they are, will need to be able to get sensible un-biassed installation and fault finding  advice easily, or the internet will fill the gaps with rubbish and misdirection.
  • Looks like the big boys are getting on the band wagon: https://www.britishgas.co.uk/the-source/news/plug-in-solar-panels-explained.html
    (I'm not sure what change is supposed to be happening to BS 7671 for this summer ... given the normal times frames and the fact that AMD 4 is already out, it feels a bit optimistic (if indeed any change is actually required)).
  • Time for a PAS (Publicly Available Specification) is a fast-tracked, BSI-developed technical standard in the UK, used to quickly establish best practices for emerging technologies, products, or services. Unlike formal British Standards (BS), a PAS is developed in collaboration with specific industry sponsors to address immediate market needs and often acts as a precursor to formal standardization.
    AI helped me with the definition of a PAS
  • Its a good idea in terms of developing something quickly, but more easily hijacked by one sponsor.  However, despite the name most PAS  (there are quite a few, the official BSI  list is here )are still usually a copyright document you need to buy to read it, so not actually of much more interest than say a BS to the DIY installer.
  • the official BSI  list is here )
    That is interesting as it does not list
    PAS 63100:2024
  • That is interesting as it does not list
    PAS 63100:2024
    There are a number of PASs not listed ... the reason for this is, if you look at the file properties, it was created in 2017, and is therefore cannot be current and comprehensive !
  • There are a number of PASs not listed
    Including PAS 0, which became available in 2012.
