Plug-in Solar supposedly going to be 'easier'?
Hi all, new to the forum.
I've been reading (various media outlets are running with the story) that the government is planning to make it easier (no mention of safety) for consumers to connect solar PV panel inverter directly to the mains using a 3 pin plug and socket arrangement.
Considering all of the current guidance regarding the connection of a solar PV inverter to the mains (dedicated circuit, own RCD, no 3 pin plug), how is this all of a sudden going to be 'safe'?
The argument that 'Balcony Solar' is all the rage on the continent surely doesn't negate the potential risks all of a sudden. Surely the IET is in discussions with government and arguing that the dangers cannot simply be swept under the carpet?
  • Just because sales and marketing state something, it does not mean it is fact.  Take the GrenFell tragedy as an example.
  • See file called 1758018154544047.pdf.  They also mention Grounding several times which is not really a term used in BS7671
    I do understand that North America say  Grounding and PDFUK people say Protective Earthing / Functional Earthing / Bonding
    But surely if this is meant for the UK market they should use UK terminology or else we will start seeing phrases like "The Hot Wire" which is their term for Live/Line but to me it sound like any oxymoron as I would never want the wires of an install to be HOT, warm I can understand but not hot.
  • Hot just means alive, or 'live', while in my day job it either means energized with RF, or radioactive..
    note we do already do see exactly this US-centric  language in instructions for things like generators that have been translated from the foreign for the UK market -   Hire a big set from Agrekko, and ask for a the  manual and the Cummins or Perkins American data you get sent uses  Ground and grounded, and hot and so on, in practice once you know, there is no problem with understanding it.
    It is however worth throwing the makers advice on NE bonding away and doing it properly.
  • Should the Insurance Industry sit on JPEL64 and advise in some capacity on Balcony Solar PV before it becomes an issue like Loft battery storage
    With fixed BESS in mind, I asked my insurers only a few days ago, "Do you impose any restrictions or conditions on solar PV installations please?"
    The answer was, "There are no restriction in relation to Solar panels. You would need to ensure that the buildings sum insured is adequate to cover these."
  • Well no more so than a slew of other dangerous things folk routinely plug into their sockets already (those series connected outdoor fairy lights come to mind, and the not quite CE compliant phone charger that catch light with depressing regularity perhaps).
    I think we need to realize this is already happening and will happen more,  legal or not, and rather like main dealers wondering why folk buy second hand cars when new ones are so expensive, there will be a need for DNOs and disgruntled MCS installers  to make the best of things whatever happens.
    If 'installation' t really has to be notified to anyone at all, there will need to be a less than 3 minute  un-notification process as well, so that when you fold it up and take it with you the registration does not persist at the wrong address. You might for example take it with you on a ten day self-catering holiday to save on the  bill at the caravan park, same as you might bring your own tinned food and 4g internet hub.
    Its probably simpler and more reliable not to bother too much at all, and just fix up only where it goes wrong.
  • It is my honest opinion that we need some rules/regulations/guidance/product standard in place for UK Balcony Solar PV sooner rather than later.
    The whole point of balcony solar is to get around the endless regulations, bureaucracy and red tape that stops people doing things.
    The kits will be type approved, like any domestic appliance. And like a domestic appliance, you buy it, take it home and plug it in. All without any inspection or paperwork.
  • They also mention Grounding several times which is not really a term used in BS7671
    There's quite a lot of that kind of thing in the IT sector - even with kit supplied by the UK divisions of very reputable companies. Sometimes it's not just the instructions either - a few things have arrived with flex with black, white and green cores - that needed some head scratching the first time.
  • I believe all the Electrical Energy Storage System fires we know about, that have occurred here in the UK, have been Lithium Iron Phosphate ..
    That's interesting (worrying even) - there seem to have been a range of chemistries available in domestic BESS systems (e.g. table 2 of https://assets.publishing.service.gov.uk/media/5f761b828fa8f55e33275cfc/domestic-battery-energy-storage-systems.pdf) and the withdrawn LGChem ones seem to have included Cobalt oxide so might have been LCO or NMC but can't have been LiFePO. If all the fires have been LiFePO but only some of the systems were, that might suggest either some people have been very lucky or we're missing a trick somewhere...
  • I'd really like to see the evidence that all the EESS fires you know about contained LiFePo4 chemistry cells. Especially as you were responsible for heading the team that created PAS63100.
  • I smell a rat with Graham Kenyon's comment. I've already found a battery fire in Nottinghamshire that was caused by a short circuit in the NMC cells used in the BESS.
