The car park
There are several main types of car park in the UK
Open air
Multi-storey open sided
Basement
Basement with dwellings or commercial space above
The UK is seeing a large move towards EV (Electric Vehicles) from traditional ICE (Internal Combustion Engine) there have also been several well documented Car park fires in the last decade.  Eg Luton Airport Car park October 2023 with over 1500 vehicles destroyed or damaged
Should all UK Car Parks apart from Open air have
Fire detection with 24/7/365 monitoring with backup power supply
Increase amount of manual fire call points per floor and throughout stairwells to increase evacuation alert
EVSE auto shut off for power in the event of a fire or an alarm
Battery backup for emergency lights for a min of 6 hours
Increased amount of illuminated fire exits signs
Fire resistant cabling throughout
Fire restitant cable management/containment throughout
Increase IP rating throughout in case of fire due to the amount of water that may be used
Annual EICR
Technology/Mechanisms to assist evacuation of disabled and mobility impaired persons, this could include evacuation lift replacing the passenger lift
As always please be polite and respectful in this purely academic debate.
Come on everybody let’s help inspire the future
  • you probably have not read https://www.gov.uk/government/publications/mgn-653-m-electric-vehicles-onboard-passenger-roll-onroll-off-ro-ro-ferries/mgn-653-m-electric-vehicles-onboard-passenger-roll-onroll-off-ro-ro-ferries
    but that has the current UK official position. I note that the recommendation is that any badly damaged EVs are placed on weather decks. Part of me wonder if that is just because it makes it easier to flood, or also because perhaps it makes things easier to push over the side if things get really out of hand, as are occasionally  the instructions for certain types of very dangerous military cargos, that they be cut loose as a last resort...
  • It is my understanding that, in neither of these cases were the vehicles that started the fire electric vehicles.
    So, in answer to the question ... 'Yes, probably ... but not just because of electric vehicles.'
    I am not trying to vilify the EV but fires do happen in car parks.  There initial cause could be by
    Malfeasance
    Mechanical fault
    Electrical fault
    Vehicle fault
    This initial cause/fault can be put aside for the moment but how the fire is detected and the alert systems used for evacuation should be more pressing as well as technology and mechanisms to help deal with the fire.  Eg A lit cigarette dropped on some rubbish could be the start of the fire but once there is a fire it starts/could start to spread from Vehicle to Vehicle and then potentially from one floor to another which could possibly be up as well as down due to gases and liquids in the car park.
    Then you can start to factor in things like blocks of flats with parking structures beneath dwellings which is becoming more common place in the UK
  • And just to re-emphasise the points made above, whist there are differences in the risks between ICE and EVs, the probability of a fire occurring due to an ICE currently appears to be higher than with an EV.
    Or in other words, cars are (and always have been) dangerous cargo whatever their fuel source.
    Just as I suspect (to go further off topic) there will be people nervous today about rail travel after the news from Spain, and hence choosing to travel by road, despite the fact that the road risks are about 100 times higher than rail risks. Familiar risks don't make headlines.
  • Yes.
    Maybe, though no need to increase within stair wells if design is otherwise compliant.
    Could already be in place via shunt trip(s) linked to fire alarm activation. If not, yes.
    No need for 6 hours. A compliant 3hr duration system should be sufficient.
    If signage is compliant, I don't see a need to increase it.
    Life safety systems should already be in fire resistant cabling. LSZH for everything else should suffice.
    Not really necessary as I would imagine smoke/heat damage would necessitate at least a partial re-fit anyway.
    Annual inspection of the EVSE installation, perhaps. Full EICR...not sure its warranted, provided any works undertaken between EICRs are properly carried out and certified.
    These would already be in place if deemed necessary for the building.
  • Oooh interesting  thank you for the link! I see though that it was withdrawn with an amendment now which can be found here: https://www.gov.uk/government/publications/mgn-653-m-amendment-1-electric-vehicles-onboard-passenger-roll-onroll-off-ro-ro-ferries/mgn-653-m-amendment-1-electric-vehicles-onboard-passenger-roll-onroll-off-ro-ro-ferries--2 Some more random info to fill up that geeky brain of mine! Joy
  • aboard an overnight ferry from France to the UK and, as how my usual geeky brain works, as we were boarding with our vehicle and parked up alongside the lorries and RVs etc belonging to our fellow travellers, I got to wondering how they deal with EVs for fire risks etc while on board?
    Have a look at the LASH FIRE - Webinar 'Fire on ro-ro deck' videos for lots of fun stuff about recent research.
  • The nay sayers like to highlight that most EVs are of recent manufacturing date, while the ICE vehicles (esp those involved in fires) are older and likely in a poorly maintained position.
    Half truths go faster!
    This probably needs to be revised
    The % of EV is growing thus more EVs will be on the average RORO Ferry
    Some Ferries are packed so tight that trying to move any vehicle becomes a logistical game of Tetris
    EV now making there way into Lorry, Tractor and Panel Van markets thus they will also start to appear on the Ferry.
    With the above in mind consider your last or a ferry crossing from Dover to Calais
    or
    Possibly
    Scotland (KennaCriag to Islay (Port Ellen or Port Askaig)
    The ferry to Islay is vital for the community but it does mean your car on the ferry could have a lorry on one side and tracktor on the other with maybe a tanker lorry infront (Tanker may carry fuel or flower or products for the Whisky Distillery). The main point is this ferry service is used to carry just about anything.
  • As stated before,
    Malfeasance
    Mechanical fault
    Electrical fault
    Vehicle fault
  • Hi Lisa
    You are always welcome to go off topic on any of my discussion threads.  As an engineering community the more we talk the more we can expand our horizons and make things better.
    All I ask is that people are polite and respectful in this purely academic debate.
