230V Supply from 400V Line to Line in a Control panel
Hi,
I have a situation where I need to install a 230V control system which draws about Max 5A ( at230V) inside a existing Dinrail enclosure.
However, the incoming (feeder) cable of this enclosure is a 3 Core + Earth and doesn't have a Neutral, as the load is 3 phase with no neutral.
My task is to provide a 230V supply for a control equipment that we are going to install inside this enclosure. I am struggling as there is no neutral available.
feeder is very long hence we cannot afford to run a neutral from the SDB to this enclosure.  either.
1) Would it be possible to mount a small control transformer and feed this with 400V supply and then generate a 230V supply ? (below link)
https://www.yesss.co.uk/eris-400va-panel-transformer-230400v-primary-122448110240v-secondary?srsltid=AfmBOoq0MCaJYskcQovSxGEfzGITtVWGUpqrmsWnTT7WLwGIsOa1xMz0
2) and if so, will this be a floating neutral ? and how do I make the neutral 0V then if required? from a practical point of view.
Thank you in advance for your support.
