Chartership through further learning at work, HND to IEng & CEng?
Hello all!
Bit of a wild card here.. I appreciate any one reading & commenting! I have kept certain institutions anonymous as I just want to shed light to my query.
I had interrupted my studies at a Russel Group university on a CIBSE & Part 1 RIBA accredited course due to carer responsibilities. 2 years on, I'm resuming my career and progression to IEng & CEng. I reached out to my personal tutor also the Head of "X course" to re-join & was told that I will most likely not allowed back due to the development in the industry/course material, the university's T&Cs on maximum period of completion & would have to re-enrol entirely. My physical transcripts are on hold due to administrative issues during my interruption.
Currently holding a HND/Level 5, I'm struggling to find any entry level work (relevant to IEng) let alone company training schemes/sponsorships without a Bachelors degree (& transcripts). Is this because the criteria to meet IEng is only through a Bachelors (in a relevant degree & accredited institution) after Sept 1999? Or is it because I do not hold a BEng/Level 6? If so I'm not able to be accepted onto an accredited and relevant top up course due to my transcripts (I tried  & was told by the admissions team to send a letter from my head of faculty confirming my attendance. To be then ignored by the admissions officer after relaying what I was told would suffice). Is it right to not wait x months/years till the next academic enrolment (or the mercy of an empathetic admissions officer) and to instead progress through relevant work experience & sponsorship?
Entry roles of interest (usually BEng level): Building Physics Engineer, Sustainability consultant, Structural Engineer, Project Design Engineer, Building Services Engineer, Environmental Engineer.
Roles I am a top candidate for (HND level): CAD Technician, usually for data centres which is not relevant in the further learning at work route to IEng?
I'm very stuck with my options at the moment as this was not part of my Net Zero initiative 10 year plan!
I would appreciate any insight into my career progression with a HND to Chartership!
To confirm my questions are:
1) Is there a route to Chartership by a Licensed Professional Engineering Institution for engineers in the UK with a HND,
2) How do I find a sponsor to get on the IEng ladder with a HND?
3) Can I apply to EngTech with a HND?
My sources;
From the Engineering council, www.engc.org.uk/.../incorporated-engineer-ieng
  • An HNC or HND started after Sept 1999 (but before Sept 2010 in the case of the HNC) or a Foundation Degree in engineering or technology, plus appropriate further learning to degree level
It then goes onto "Please note:
  • You can still become an IEng without these academic qualifications. Further information about the individual, work-based, assessment process can be found in UK-SPEC and from your Licensed PEI "
My Licensed PEI: CIBSE https://www.cibse.org/media/5izkxlj2/acibse-application-guidance-2021.pdf CIBR19123 Associate Application Guidance v2
"If you do not hold an exemplifying qualification for IEng, you can take the experience route as depicted below."
"Find a sponsor who can support your application."
From my university:
Absolute maximum period for completion – Full-time
Honours Degree 6 years
"The school will then need to judge whether, in the light of these circumstances, it is possible for the student to complete their studies within a period that sufficiently ensures the currency of their knowledge, their competency and the quality of their degree. If the school believes that it is, on balance, appropriate to extend the absolute maximum for that student, they will then provide a new absolute maximum to which the student must adhere."
  • The engineering council does not require any equivalent to a masters for CEng.  A recognised MEng or recognised batchelors with recognised masters can be used to demonstrate UK&u but there is the IET individual route too. Over 70% of applicants to the IET adopt this non recognised route.  The requirement, as copied from V4 UKSPEC is:
  • Through the individual route you are assessing for an equivalence. Equivalence comes in many forms, which that paragraph details. It may be formal courses, but it may also be work-based and experimental learning. There are many options.
    There is a further guidance note from the Engineering Council that deals with international degree recognition and degrees from pre-UK-SPEC (like mine, which was SARTOR).
    I don't precisely know how the IET assesses UK&U, but I do know how my other institution does it. Given they are both meeting the underlying Engineering Council standards, I would suspect they are similar.
    I've been involved in more than a few assessments over the past few years through my other institution.
  • Lots of very sound replies and advice here already so not going to add a lot but to summarise some salient points
    • There is no formal education requirement for IEng or CEng - it is an 'equivalence' demonstration if an accredited course is not completed and fundamentally is about the perceived gap to assumed UK&U
    • There is a route with zero qualifications (I got a Warrant Officer with no formally recognised technical quals through to CEng). It is the Technical Report Route and consists of submitting a detailed document on one or two technical projects complete with demonstrations of the technical content, understanding of appropriate equations etc. If successful, UK&U is demonstrated and its straight on to a normal IEng/CEng interview
    • Show how you learned: I had to use this new widget and here is how I learned how to use it or make technical judgements or analyse etc ... much of the AHEP differences are around key technical understanding and the ability to analyse and make recommendations
    • Final point is that UKSpec is under revision and there will likely be a fair bit of change both in terms of competence areas (it is not being dumbed down), and expected behaviours. Professionalism and being safe I would expect to be more prominent. This in practical terms won't roll out into IET applications for at least 2.5 years but if your timetable is longer then no hurry
    • Find a good PRA (one who assesses and interviews as they will have the best broad knowledge of how to get over the UK&U difference. Make sure they will be in it for a long haul and willing to iterate, challenge and be a critical friend
    A useful initial guide to the AHEP standards is here and there is a handy top level table showing the kind of differences that are supposed to be demonstrated
    https://www.engc.org.uk/media/isdl1tem/the-accreditation-of-higher-education-programmes-ahep-v44.pdf
    Good luck !
